Moderators: Random Orbital Bob, nev, Charley, CHJ, Noel
 Reply
By Farm Labourer
#1336234
A couple of weeks ago, I finished an iroko coffee table for my "God-son". I brought the various elements into the house from my unheated workshop when gluing to ensure adhesion. The parts then went back out to w/shop for finishing and then came indoors for Osmo.
It's been in the house now for a couple of weeks and I've noticed that some of the mitres are moving - probably about a quarter of a millimetre but it's obvious.
I'm thinking of taking the top back out to the workshop and routing some dovetail grooves across the mitres and fitting dovetail pins of iroko.
Is this a sensible approach or are there better options?
You do not have the required permissions to view the files attached to this post.
User avatar
By AndyT
#1336240
MikeG. wrote:Mitres? Where? I can't see any.
Nor can I. If there are any, consider your problem solved!
By Farm Labourer
#1336242
Apologies - much better at cutting myself with a chisel than I am with cutting-edge technology :D
User avatar
By MikeG.
#1336243
Ah, right. They're a bit of a nightmare in that situation. If there is any movement in the table top it will either bust a corner apart, or curve the edge piece leaving a gap adjacent to the corners. I've avoided that detail for years now after a bad experience.
User avatar
By custard
#1336246
I'm a furniture maker, I often try and bump up the revenue on a commission by including a mirror in a matching timber.
I cut lots of mitres, but it's mirrors that count for the majority.
You don't need to go from an unheated workshop to a domestic location to cause problems. Mitres are notorious for opening up and just normal seasonal humidity changes can be enough for a tiny gap to open, which will then fill with dust and over the years look increasingly unsightly.
The solution is to mechanically support the mitre across as much of the joint as possible. There are lots of ways of achieving this, a half lap mitre, splines either blind or through, or the rugby ball shape of a biscuit are all common solutions. A lot depends on the application, the budget, and what equipment you have available. But for your table I would have suggested either hidden plywood splines, or if I needed a quicker solution then a through spline that would have been visible from the edge, you could even make this into a feature by using a contrasting timber.
You may hear suggestions that modern glues are capable of dealing with the problem. Not in my experience they're not. Even with the kind of sophisticated cramping solutions that you're unlikely to have access to, the glue joint on a mitre is basically end grain, and it's very unlikely to protect against the constant seasonal working of the timber across a mitre joint. That's why I say the real solution is to beef up the glue's strength with mechanical assistance across as much of the joint as possible.
Good luck!
By Farm Labourer
#1336247
Thanks Mike. It did cross my mind that I might spline them on the inside (or even biscuit them as they must be about 60mm deep on the 45degree line). I actually found it a bit of a pipper to clamp up dry and it was even harder when glued - so was temporarily pleased that I'd not introduced further buggeration.
Any helpful repair suggestions?
User avatar
By AndyT
#1336260
I think part of your problem is that the table is still new and may not have settled down from its recent changes of temperature and humidity. So it could make sense to wait and not do anything permanent yet.
So if the gap bothers you, I'd suggest some wax repair sticks. Heat a tiny screwdriver in a lighter flame and use it to heat the end of the stick so a drip goes into the hole. Smooth it down with the same tool and polish off when it's all cool.
This has the advantage that if there is more movement - and if the crack closes again - the wax will give, and the wood won't split.
Use wax a shade darker than the wood.
By Farm Labourer
#1336264
Custard - our posts crossed! Yes, I do have some offcuts but this is a five-year overdue wedding present - so no way I can capitalise!
Andy - good idea but I'd like to hand over something quasi-stable at the end of this month, the big reveal, I think they call it across the pond!
So.... are my routed dovetail "tails" a sensible and appropriate solution?
User avatar
By MikeG.
#1336265
Before you do anything, stick a clamp across the joint and see if it will pull up. If it won't, the question of how to hold the mitre together is moot. If it will, well, it's simpler to just glue in a flat spline rather than a dovetail.
By Farm Labourer
#1336296
ST - the top is three wide-ish boards of iroko, from memory - 9" centre and two at 7" and out of the thicknesser at about an inch. However, these have been on the shelf for at least a year, so I'm hoping movement will be minimal in iroko.
User avatar
By woodbloke66
#1336332
Farm Labourer wrote:ST - the top is three wide-ish boards of iroko, from memory - 9" centre and two at 7" and out of the thicknesser at about an inch. However, these have been on the shelf for at least a year, so I'm hoping movement will be minimal in iroko.
You've got nearly 600mm of solid timber to make the top; with the best will in the world, I suspect that it will move. If it expands just a smidge, it'll burst the mitres; if it contracts it'll pull away from the edge lipping(s) so whatever you do, you could be in for problems in the long run.
Many years ago I built a solid oak coffee table about 800mm dia from several boards that had been in a warmish school workshop for many years so I thought that all the movement in the boards was done n'dusted. Once the table encountered a change of environment, the total shrinkage across the grain was about 5mm - Rob
User avatar
By custard
#1336397
woodbloke66 wrote:You've got nearly 600mm of solid timber to make the top; with the best will in the world, I suspect that it will move. If it expands just a smidge, it'll burst the mitres; if it contracts it'll pull away from the edge lipping(s) so whatever you do, you could be in for problems in the long run.
+1
I'd assumed the centre section was veneered, if it's solid then chasing a mitred lipping is really just a fool's errand. No matter what you do some movement is inevitable with the changing seasons (even though here in the UK with our maritime climate there's far less actual movement than you'd experience in the continental climate that prevails across much of the USA or Canada), but even that relatively small amount of movement means a gap free mitre is unachievable.
You could make the centre section "float" within a mitred frame, but then you're looking at a pretty substantial gap between the frame and the centre panel, so whatever you do a tight, gap free solution isn't really viable.
User avatar
By Lons
#1336404
A close friend now sadly deceased had made a dining table with a similar design top except it was all oak. The "frame" part was roughly 100mm wide and the table over time moved constantly, not too much but it drove him nuts.
Eventually he took his router with a V bit and routed a shallow groove between the join of frame and centre section as well as across the mitre on each corner. It looked OK to me when I saw it and though the table still moved he said it was barely noticeable.
