 Reply
By hanser
#1329806
Free to a good home
If anyone has a use for a machine stand for a De Walt 1251 RAS let me know. It's the genuine DW part.
Collect from Nottingham or it can be dismantled and mailed at your cost.
By SammyQ
#1329807
Hanser, I am interested, but to have it as a secure table for a heavy mortiser, rather than an RAS. Accordingly, if there is interest from DeWalt users, I will step aside.
Sam
By julianf
#1329833
I have a 125 (same as the 1251) without a stand. It's not set up at the moment because my garage has no roof on it currently.... : /
But making a stand will be on my to-do list.
I was considering the top last night. I know the sawdust plan is to make a wooden top with strips of metal in it, but I did wonder about using a simple thick steel sheet. But then maybe I should make a larger / wider stand anyway?
By hanser
#1329931
Hi guys
Thankyou for your interest.
On the basis that SammyQ was the first to respond I propose to offer it to him.
SammyQ - a pm will be on its way shortly,
Regards
H
By julianf
#1329972
No problem at all for me - as i say, im in two minds as to if i should build a wholly steel table on castors anyhow.
(im much more adept with metal than i ever will be with wood!)
Let me know, however, if nothing comes of it with Sammy, as a quick solution may still be more desirable than me planning something for the next however long...
By hanser
#1330040
Hi Julian
Thanks -I guessed from your post that you had not quite made up your mind.
I have provided some more info to Sam who confirms that it will do for his purpose. I am pleased it will be put to good purpose.
Thankyou for your interest and good luck with the re roof.
H
By SammyQ
#1330070
"good luck with the re roof."
Seconded. And have a blast designing and building your saw support.
Sam
