 Reply
User avatar
By PeteG
#1314727
I haven't been able to download an Avatar image from my PC for months. I've tried several times
making the images different sizes from 140 x 140 pixels and below to a maximum of 8.93 kiB
or less. Please help :D
User avatar
By nev
#1314757
As you see :) It Should work, there are no restrictions or faults as far as I can see. make sure that the file name extension is the correct format e.g. .jpg
edit: that image is a .jpg 68x90px, 7kb, (with a resolution of 72x72, but i dont think that matters).
If you still have no joy attach your desired image to a post and I'll try it from this end.
User avatar
By PeteG
#1314767
nev wrote:As you see :) It Should work, there are no restrictions or faults as far as I can see. make sure that the file name extension is the correct format e.g. .jpg
Appreciated Nev, but still no luck. Tried again with the same Jpeg image at 50 x 59 px.
After clicking submit it says Profile update, but it hasn't replaced your image.
User avatar
By nev
#1314768
attach it to a post and I'll try it
User avatar
By PeteG
#1314770
Cheers Nev :D
Finished Table Avatar2.jpg (19.54 KiB) Viewed 734 times
User avatar
By nev
#1314774
It was still too big pete. Had to reduce it in size even more which results in the blurry image. Id try with a copy of the original image and reduce the amount of colours in it and then reduce the size (in pixels) and see if you can get a clearer image.
Have to go out now but will have a bash later.
User avatar
By PeteG
#1314780
Appreciated Nev. It was only showing 8.6 K in Photoshop. I've made it very small and it's downloaded,
but like you say, the quality is very poor.
User avatar
By nev
#1314805
This is pinched from your WIP post and resized with the above program and claims to be below the required size.
User avatar
By PeteG
#1314809
nev wrote:This is pinched from your WIP post and resized with the above program and claims to be below the required size.
You star Nev :D Thank you very much that's perfect...
