 Reply
By rafezetter
#1295074
Well.. after snapping yet another old screw head off while trying to remove it from a door frame - anyone with a good engineering lathe fancy taking a bit of high carbon steel rod about 10mm OD (biggest easily available dowel size) and drilling a hole in it about 8mm ID?
Around 100mm would be enough I think, and I can cut the teeth and harden it here.
If you think 10mm OD is a bit skinny 12 would do and I'll just have to make my own dowel plugs.
I've looked about and cannot seem to find a commercial thing for this that isn't under £35 (yes I'm being tight) and has a 10mm OD - because some old slotted head screws in doors are quite fat, so maybe could be something to sell? Almost all woodworkers / handymen have snapped screws in thier time and could use a good tool steel screw remover - I do enough door type work - usually fixing hinges or replacing doors etc that when it happens it's a major PITA both to sort out and eats into the time quoted as well.
In case you ask - I've got a cunning plan to stop it wandering as one makes the initial cut, my patented block of wood with a 10mm (or 12mm) hole in it :)
User avatar
By ColeyS1
#1295078
I bought a stainless steel straw off of ebay then cut some teeth on the end. Its saved hours of work and there was enough length on the straw to make several holesaws . Ebay number 283182521090 looks like it might keep you going for now
Sent from my SM-G960F using Tapatalk
User avatar
By Trevanion
#1295082
Sounds like an interesting idea, I think I've heard it here before because I for some reason remember someone saying sharpening an Ikea stainless tube works well? :?
Basically this but longer? Wouldn't be too much trouble on my gear and I've got some 10mm and 12mm silver steel knocking about.
By Rorschach
#1295129
sunnybob wrote:For this price I would think its worth trying out?
https://www.amazon.co.uk/Diamond-Coated ... 4KDCCG3ZH9
Won't work very well on wood at all. They don't last that long on hard tile but they are so cheap it doesn't matter, I buy them in 10's from China for pennies, as long as I get 1 hole I am happy (usually get 2-3 holes per bit)
By rafezetter
#1295269
Wow lots of replies - ok plug cutter: too short, as with all forms of cutter that has a central solid shank, I need to be able to get the entire screw out not just dig out the top section of surrounding wood - the remaining threads in wood still puts up a hell of a fight to remove it.
I do have a plug cutter set - the 4 pronged type, where the largest will cut a plug that matches the hole created by the smallest plug cutter - but again, too short, bottomed out halfway, followed by much cursing, stitch drilling and more cursing. (If I'd been at home I'd have been tempted to take my pencil torch to it and burn the pipper out.)
Some people seem to think that putting much longer screws into the frame or door helps - even long screws directly into the aerated brick, so I'll need all the length I can get.
Re the ali / brass tube suggestion, this recent one was in oak, so can't see that working at all tbh. As Rorschach says I'd already dismissed the diamond grit ones for similar reasons as well as "too short internally".
I had wondered about stainless 304(?) as apparently it's harder than mild steel, but dunno for sure.
The rolled pins could be a winner though, definitely worth looking into ty Inspector.
By novocaine
#1295369
As good a response as I can think off. :D
I tend to drill out as far as possible with the 9.5mm plug cutter, crack it with a small chisel to remove the plug the use the drill chuck to grab the broken screw that's now exposed and wind it out that way. Doesn't always work but maybe 8 out of 11.
Bit more faff than a small long cutter though I agree. Haven't got access to the lathe right now or I'd sort it out for you.
By Jacob
#1295384
Just wondered what procedures OP uses to remove old screws. There are various wheezes. Basically they don't break if you do it right unless they are seriously rusted in solid - common in oak but usually no prob in pine and other timbers.
