 Reply
By sploo
#1288673
I've seen a few references to finishing the last few turns by hand when cutting a thread (where it's not possible to have a relief cut, so risking a crash with the lathe powered). I have basically zero experience of thread cutting on a metal lathe though.
That got me thinking - is there a minimum rpm speed required for thread cutting steel, using HSS cutters?
The reason I ask is that I'm looking at building a 4th axis for my CNC milling machine, and its main use will be for turning very large objects (e.g. 40cm diameter) - so I'm planning on gearing it to run very slowly (e.g. maybe 5 to 10 rpm; but obviously with significant torque). With appropriate cutting depths, and a sufficiently rigid tool mount, would there be any issue with getting it to turn threads on ~3mm to 20mm diameter stock at this sort of rpm?
I guess this comes down to whether HSS cutters have a surface feet per minute sweet spot; and this low rpm combined with a small diameter would be just too slow.
User avatar
By AndyT
#1288694
My metal lathe is treadle powered, so is a bit different from yours, probably. However, when cutting threads I have had some success when pulling the flywheel round by hand, very slowly indeed. Using HSS tooling, I could keep peeling away swarf at very slow rates of cutting. So I'd suggest that there is no minimum speed.
You could think of it as the sort of speed you might use when rotating a die by hand to cut a thread.
By sploo
#1288835
Rorschach wrote:It's not RPM you need to worry about, it's surface speed and that depends on the diameter of your work.
I'd hoped to head off that reply with the last paragraph of my original post :wink:
Yes - the reason the planned 4th axis will turn so slowly is specifically because I need to be able to achieve a safe surface speed for a milling head when a large diameter object is being turned.
AndyT wrote:My metal lathe is treadle powered, so is a bit different from yours, probably. However, when cutting threads I have had some success when pulling the flywheel round by hand, very slowly indeed. Using HSS tooling, I could keep peeling away swarf at very slow rates of cutting. So I'd suggest that there is no minimum speed.
Excellent point about die cutters. As I hoped/suspected, you're probably right there's no (realistic) minimum speed.
Last night I happened to watch a video that included a guy cutting a keyway using a DIY lever jig, and of course that's just peeling away shavings of metal by hand (low speed, high torque due to the leverage).
Hopefully it'll be OK then. Certainly opens up a few interesting extra possibilities with the 4th axis. Thanks.
By Rorschach
#1288853
Sorry, missed that bit.
Yes there are sweet spots but a sharp HSS tool will cut at any speed, as mentioned before, tapping and threading with dies is done at very slow speeds.
By AES
#1288855
I don't have as much experience of "powered" thread cutting, but when I do use my little lathe for this I always turn the chuck by hand, not in powered mode. So in principle I'm just using the lathe as a "jig" to hold everything square and parallel!
I think in a production environment (e.g. capstan lathes) there are min speeds but as for me "time is not of the essence" I don't bother even looking for such data. I'd also suggest that as the thread you're planning is for that special purpose and is a one-off you've nothing to loose by going slowly.
Dunno if that helps or not!
By sploo
#1288858
Rorschach wrote:Yes there are sweet spots but a sharp HSS tool will cut at any speed, as mentioned before, tapping and threading with dies is done at very slow speeds.
Dunno why I didn't think about manual tapping and die cutting before Andy mentioned it - kinda obvious when someone points it out.
If I can create a sufficiently rigid tool holder (the machine by default will use a milling head) then it does open some interesting possibilities for making unusual threads.
AES wrote:I don't have as much experience of "powered" thread cutting, but when I do use my little lathe for this I always turn the chuck by hand, not in powered mode. So in principle I'm just using the lathe as a "jig" to hold everything square and parallel!
It does - many thanks!
By sploo
#1288877
Rorschach wrote:If you are using a milling head for the tool then you could mill the threads which would be incredibly fast and clean. Or was that your plan?
It wasn't necessarily the plan; partly because I'd need a suitable milling cutter. I wouldn't be against trying though.
By Rorschach
#1288884
I reckon if you are cutting the size threads you mention then it would be a good option. Tool load is reduced, cutting speed is faster.
By sploo
#1288905
My concern would be the life span of (the tip of) a v-cutter required to do this. That said, I hadn't realised that the metric ISO and Unified National threads both use the same angles and widths for the tips and troughs of the threads. As long as the tip of the cutter is >= p/4 (where p is the pitch) it should work.
By sploo
#1288940
Rorschach wrote:Well it's widely used in industry so I imagine commercial cutters have very good life.
I did find a 60 degree v cutter, but the tip was 0.4mm. Given the p/4 width for the bottom of a thread, it would limit the minimum pitch to 1.6mm (so only good for an M12 coarse and larger).
I assume there must be some steel-capable cutters with finer tips, but to mill an M4 fine thread (0.5mm pitch) would need a tip of 0.125mm; so pretty delicate.
