 Reply
By S S
#1273244
I see from a few searches this has been discussed a fair bit already, but most of the time it's from the point of view from having only either one of these. Currently in my little garage I've got a circular saw, a sliding mitre saw, a router table and a planer/thicknesser.
I've mostly been making smallish bits of furniture out of pine whilst I get my skills up but I'm really struggling to make accurate rip cuts, especially in thin pieces of stock.
Considering I have a mitre saw for most of my cross cuts and a circular saw for bigish panels would I be better off with a table or band saw for these long cuts, or just try to make some form of jig to use with my circular saw?
If the cut isn't that flat I can probably clean it up with the P/T, but space is really becoming an issue at the moment.
The fact that a bandsaw is also a bit safer than a table saw also sounds nice, also I imagine I could get a better bandsaw than table saw for under £400.
Any advice would be greatly appreciated!
User avatar
By woodbloke66
#1273247
S S wrote:I see from a few searches this has been discussed a fair bit already, but most of the time it's from the point of view from having only either one of these. Currently in my little garage I've got a circular saw, a sliding mitre saw, a router table and a planer/thicknesser.
I've had a couple of table saws and have given them up in favour of a band saw (I have two). In a small 'shop where space is at a premium, a table saw occupies a lot of it, especially if you start to fit extension tables. I also use a Bosch hand held circular saw for rough cutting planks and boards to approximate size, but it's quite possible to make a really accurate cross cut jig for it as well. For long cuts, just clamp a straight edge to the board and run the saw down it; dead easy - Rob
User avatar
By Lazurus
#1273251
I had just a bandsaw for 20 years and until last year when I treated myself to a table saw, I did everything on the bandsaw and the P/T. Just ensure it is set up accurately and they are a wonderful bit of kit
By sunnybob
#1273272
Under 400 is unlikely to get you a satisfactory machine whichever one you choose.
trust me, I HAVE been there and DONE that.
I have just (finally) bought a dewalt 745 site saw because just like you I am very limited on space. That dewalt might be small (ish) but it is a VERY VERY good saw and I am really enjoying finally making long straight cuts. Its saving me hours in cleaning up cut edges
But I have a 350 (wheel diameter, its how bandsaws are classed) bandsaw, and if a gun was put to my head and I had to choose one over the other, it would be the bandsaw I would keep.
By sunnybob
#1273278
The question, was which one?
My first answer, is both.
My second answer is if I did not have room or could not afford both, I would have the bandsaw.
User avatar
By MikeG.
#1273279
You've got a hand-held circular saw. All you need now for accurate rip cuts is a long straight-edge and a couple of clamps, and a pair of saw horses.
User avatar
By MikeJhn
#1273284
phil.p wrote:OP - you don't say whether you have or intend to get a lathe. If so, the bandsaw wins hands down.
And if you get an airplane you will need a hanger and an airstrip, and later in life if you get a wife that will involve a mother in law, so a gun would come in handy as well.
User avatar
By MikeG.
#1273285
MikeJhn wrote:And then setting up over and over again for repeat cuts, if cutting long repeat rips you can't beat the ease a table saw will give you.
If space isn't an issue, you're right. But it is:
S S wrote:........in my little garage.........
User avatar
By woodbloke66
#1273296
MikeG. wrote:You've got a hand-held circular saw. All you need now for accurate rip cuts is a long straight-edge and a couple of clamps, and a pair of saw horses.
Agreed Mike...beat you to it! (See what I writ :D ) - Rob
