Moderators: Random Orbital Bob, nev, Noel, Charley, CHJ
 Reply
By Wattsjoinerybarn
#1266939
Hi all, brand new to the forum so apologies if this has been covered recently but couldn’t see it.
I have a small workshop and have done quite a few cabinets to date but am finally doing my first kitchen! It’s an in frame kitchen with a 37mm frame the carcass is 19mm and sits flush with the outside of the frame. Basically I want to use some sort of clip on cabinet hinge but to get the door to be centred in the frame I need to pack it off the carcass by 18mm and then use an inset hinge. My question is where do I get 18mm spacing mounting plates from at a decent price and brand selection or is there such a thing as cranked inset hinge that will do it one. It is frustrating as I have done this before a long time ago before I got my shop and found the spacing plates on eBay I think. Anyway any help would be appreciated
Thanks in advance Matt
By Wattsjoinerybarn
#1266952
thomashenry wrote:Butt hinges every time in this scenario.
Thanks for the quick reply but soft close plus the ease of adjustment are my reasons for avoiding Butt hinges.
I can get a 18mm spacing plate for Blum but no other brands and tbh even the Blum ones are hard to source in bulk.
By peter-harrison
#1267057
Blum and Grass do cranked hinges which is what you are after. They are a bit more expensive than standard overlay hinges. They are also bulkier which you need to bear in mind if you are having drawers behind doors or suchlike.
https://www.hafele.co.uk/en/product/con ... 7&PDP=true
https://www.trade-hinges.co.uk/soft-clo ... et-3-p.asp
By thomashenry
#1267574
Ok, so I can’t talk you out of Euro hinges...
Perhaps I don’t understand the question, don’t you just need to attach some 18mm packers to the side of the cabinet, behind the face frame??
