 Reply
By Tetsuaiga
#1255058
I've recently decided it doesn't feel right to use these species.
I wonder why they're pretty easy to get hold of though, blackwood, ebony, wenge, many more for example.
Does it make any difference to you if the wood comes from somewhere it's certified? I imagine it probably is quite easy to have documents fairly signed in many of the countries these timbers come from. Just using the wood even if it is ethically sourced still encourages the admiration of it.
I have some planks of wenge that now I now not sure I want to use. I suppose the only option is to sell it to someone else or just use it but resolve not to buy more again.
I'd like to hear what others think about the issue.
By sunnybob
#1255061
Ask yourself what will happen to all the wood YOU wont work with.
Will someone else use it (oh yes)
Will the foresters stop cutting it (oh no, or they wont be able to feed their families)
Will the land developers stop cutting it (oh no, because then they couldnt build houses for the people who want to buy them. And if they couldnt sell it, they would burn it or just landfill it).
There is no way you can change the world, Not even if every woodworker in the world switched to just going out and hugging trees instead of making stuff.
Use it, and maybe feel a little sad, but dont stand back and let it be burnt or buried.
User avatar
By MikeG.
#1255063
sunnybob wrote:........There is no way you can change the world, Not even if every woodworker in the world switched to just going out and hugging trees instead of making stuff........
That's not very logical, sb. If no-one buys the stuff, it has no value and won't be cut down.
If it's on the CITES list, it's illegal to trade it. If people carry on buying it, all they are doing is enabling and encouraging criminal activity. If people stick to using wood from certified sources, they strengthen the certification schemes (such as FSC), spreading knowledge of it amongst consumers and suppliers. Eventually suppliers will be pressurised into better practises by the spread of such schemes, because if all consumers demand certified timber they'll have no choice but to supply it.
As to the idea in the OP........it's the act of buying the wood in the first place which is where the mistake was made. What you do with it now is irrelevant.
By sunnybob
#1255065
You missed the point. almost all of the forests around the world are being chopped down for farming and houses. that wood is doomed. End of story. If it cant be sold it WILL be burned. Logging for export actually makes some use of the wood and gives local people income. Without buying the wood you are condemning the locals to poverty. It is your DUTY to buy wood.
=D> =D> :D :shock:
User avatar
By Marineboy
#1255071
sunnybob wrote:You missed the point. almost all of the forests around the world are being chopped down for farming and houses. that wood is doomed. End of story. If it cant be sold it WILL be burned. Logging for export actually makes some use of the wood and gives local people income. Without buying the wood you are condemning the locals to poverty. It is your DUTY to buy wood.
=D> =D> :D :shock:
On that logic then we should be encouraging African poachers to keep killing elephants and rhinos so they can keep selling their body parts to the Chinese.
By Beau
#1255076
I went to a great talk on this subject hosted by David Savage some years back. Both sides put forward fantastic cases but to honest I left none the wiser. It was a classic chicken or egg argument. Personally I stopped using exotics apart from what I had in stock and I only use these for details now. I used to be pretty naive on the whole matter. I used to by rosewood and wondered why it came with a machined groove in it. Later found selling what was classed as a product got around CITES protection :cry:
By phil.p
#1255082
That's why you can buy oddly shaped little blocks of backwood - they're sold a clarinet bell blanks.
I did read albeit a long time ago that 90% of what was felled in Brazil was burnt, and the the UK took only 1% of the remaining 10% - most of the rest (at that time) went to Japan for single use building shuttering etc. You can probably substitute China for Japan now.
Much of what is cut now is cut to clear land for palm oil production and other food crops so how much difference in the greater scheme of things does cabinet making make? If we make the stuff valueless I suppose there is an argument to say that would make it more likely to be destroyed rather than less?
By sunnybob
#1255087
=D> =D> :D :shock:
No, that is not logic.
Poachers ONLY kill to sell to chinese (and other nationals of course). If those people didnt buy, then poaching would stop.
Trees are burnt to clear land for people to live and to eat.
using your logic, you have to ban the people. Wipe out the people, you wipe out the demand for cleared land, and you save the trees.
User avatar
By MikeG.
#1255093
sunnybob wrote:......Trees are burnt to clear land for people to live and to eat...........
This simply isn't the case, Bob. That happens in Malaysia and South East Asia, but it isn't what is happening in South America or Africa. You are generalising too much. Illegal logging for timber is the major driver of tree loss in west, central and southern Africa. We're only a year or two away from there not being a single stand of mature trees left in Mozambique, and that is driven entirely, 100%, by the Chinese demand for cheap timber.
Wenge, as discussed in the OP, is from west and central Africa. There is no central government with control outside the capitals in the DRC or CAR. Every tree cut there is illegal, and the felling is on a massive industrial scale.....again, most of it for timber or pulp, and almost none of it for the land or for palm oil production. That felling which isn't driven by logging is for mining operations, again, all (or almost all), illegal.
User avatar
By MikeG.
#1255094
sunnybob wrote:......... Poachers ONLY kill to sell to chinese (and other nationals of course)............
Sorry, Bob, but this is twaddle. Most poaching in Africa is for the bushmeat trade, and is sold to locals.
By sunnybob
#1255112
Mike, if its sold to and eaten by locals, I dont feel too strongly about that. If the alternative for the locals is to starve, while they watch elephants destroying their crops, then I'm on their side. I have been to africa, I have seen what a large herd of elephants can do to crops and surprisingly even trees, where they eat only the small new shoots at the top of the tree, but snap the branches in half to get to them (I was kept awake for a whole night once while a herd of them destroyed a small copse of trees nearby. When daylight came, I saw trees with 6" trunks ripped down the middle as if struck by lightning).
But thats somewhat of a diversion. However you look at it, its PEOPLE who are causing the loss of trees. Whatever the nationality, the wood is in demand.
What a half dozen, or even several thousand hobby woodworkers buy, is neither here nor there.
By Beau
#1255113
sunnybob wrote:What a half dozen, or even several thousand hobby woodworkers buy, is neither here nor there.
Utter rubbish. You cant absolve responsibility with an argument that weak. Anyway there are plenty of pros using greater quantities on here anyway.
It may be a drop in the ocean but the ocean is made up of lots of tiny drops.
User avatar
By Marineboy
#1255114
sunnybob wrote:Mike, if its sold to and eaten by locals, I dont feel too strongly about that. If the alternative for the locals is to starve, while they watch elephants destroying their crops, then I'm on their side. I have been to africa, I have seen what a large herd of elephants can do to crops and surprisingly even trees, where they eat only the small new shoots at the top of the tree, but snap the branches in half to get to them (I was kept awake for a whole night once while a herd of them destroyed a small copse of trees nearby. When daylight came, I saw trees with 6" trunks ripped down the middle as if struck by lightning).
Perhaps we were wrong to get rid of bear-baiting as we then deprived the bears' owners of a living.
