Poolewood 28-40
RytonJohn
New member
14 Mar 2018
Gloucestershire
I've just acquired a fine Poolewood Superlathe model 28-40. But I need some advice about it and I hope someone can help me.
The lathe is in fine condition but when the previous owner had it, after using it successfully for some time, the motor start capacitor exploded. From the debris, it was not possible to know what its value had been. I have spoken to Poolewood and also to Axminster but they cannot give me the information I need. After some internet research, which produced some rather contradictory advice, I thought a 200 mfd capacitor would be about right and I fitted one. If I slip off the rubber drive belt, the motor starts immediately and reaches full revs quickly. The centrifugal switch operates as it should. So far so good. But with the belt replaced, the motor will not overcome the inertia of the "gearbox" and just buzzes. It is a 1 HP single phase motor and I'm sure it is the original motor. The bearings of the "gearbox" appear to be in good condition, to turn freely and to be properly lubricated.
I am hoping that a Poolewood 28-40 owner with a working lathe could please (a) tell me what value the starting capacitor should be and (b) ideally send me a photo of the wiring inside to make sure that I have correctly fitted the capacitor and (c) point me in the right direction to get this machine working.
I'll be very grateful for any advice.
RytonJohn.
For starters it will be necessary to determine exactly which variant you have, the design and specification changed over several incarnations of the '28-40'
Is the motor a very large and heavy slow speed six pole motor? or is it a smaller version?
The later electronic speed control version would not have a running or starter capacitor.
Also be aware that the 1-1/2" X 6 thread can be either whitworth or UNC dependant on version.
poolewood-2840-t45405.html
28-40-lathe-head-stock-rebuild-bearings-belt-etc-t24306.html
http://www.quest42.co.uk/woodwork/poolw ... flets.html
This help? It's a 1HP six pole motor.
VERY helpful. Thank you very much. I've ordered a 300 mfd cap and will see if that does the business. It looks as though the machine you photographed for me is the same model as mine .
