Drawer slides for shallow drawer
will1983
14 May 2014
Crewe
Hi can anyone recommend a set of drawer slides for a shallow drawer?
These need to be soft closing and full extension but not necessarily concealed.
I have Blum Tandem slides for the rest of the regular drawers in my dressing table build but these require a minimum of 25mm from the bottom of the opening to the underside of the drawer bottom. With my opening only having a clear dimension of 88mm this would leave me with less than 63mm drawer depth.
side mounting ones as myfordman says are 1/2" std width and far far easier to find than bottom mount. you'lleven find them in the big orange shop
Thanks Brandlin, I've found some on the buller site that should work for me.
