Table insert
Don't know about your saw, but if it is by Clark, it probably has many clones.
Straight away I found a clone by Nutool.
Maybe look for the same by Axminster, Sip, Draper, Charnwood exc if you really want one.
Why would you not make your own zero clearance insert from hardwood ?
I found it to be much better than the aluminum one on my saw, as there was a huge gap for slivers to fall into.
It was also lower than the table, and I did not have an allen key to fit the adjusting screws to level it.
This step left visible saw marks in the timber.
I still use the aluminum one for angles so far.
Tom
