Kreg beaded system
carbo
23 Dec 2008
doncaster
Been looking at the kreg face frame beaded system .....
It appears however it's only available overseas? Does anyone know a U.K. Dealer that could source one or recommend a reliable US dealer as I'm nervous because it's so expensive for what it is.
Cheers in advance
Hello,
Can't help with a supplier, but everything that jig does can be done on a router table anyway. Something to fit the mitre slot for the notch cuts should be easy enough to knock together, if you don't have a mitre gauge with a sacrificial fence. I make birds mouth mortice and tenons with a simple shop made guide, and actually use proper tenons, not those godawful pocket screws, which are totally pants for making frame joints that will actually last more than 5 minutes.
Mike.
