Jacob
Just been making a peculiar window sash - 2 panes high, 6 panes wide. It's for an internal borrowed light and unlike anything I've made before.
In view of the width I thought the short vertical bars should go through - to keep the top and bottom rails straight and tied together.
This means cutting the one horizontal bar into 6, with stub tenons at each end.
Sounds good so far - but what I found was that a tiny error on the horizontals was accumulative and causing the stiles to bow out slightly.
This meant time wasted carefully checking and easing all twelve ends, and a couple of dry runs.
I normally get it right first time with perhaps just having to ease one or two joints, so why a problem here?
Answer is: say each piece at each end was 1mm too long, that'd accumulate to 12mm error at the stiles.
But if the horizontal had gone through and the verticals cut instead there'd only be a 4mm error top to bottom, and 2mm end to end.
Furthermore - the rails were not moulded, so the joints could all have been eased in seconds by dropping a saw cut down the gap.
Moral of the story - a multi-paned window then let the long bars go through and only cut the short ones.
Except of course you can't do this with a vertically sliding sash as the the verticals must hold the top and bottom rails together.
