UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Author Message
PostPosted: 29 Nov 2017, 09:46
Offline
Settled in Member
User avatar
Has thanked: 64 times
Been thanked: 58 times
Looking good. I built my "Sellers bench" earlier this year as a beginner too, it was a great learning experience. It did feel a bit overwhelming at times but once it's done it's a damn good feeling.
I started out with CLS and QUICKLY realised that planing all the round edges down to flat and square was going to suck. So started again with PAR. First lesson learned...
 Profile
PostPosted: 04 Dec 2017, 17:04
Offline
Settling In
Has thanked: 2 times
Been thanked: 5 times
Got your mortices done yet Nick? Took Sellers ages in whatever those legs of his were, sounded solid!
 Profile
PostPosted: 05 Dec 2017, 00:17
Offline
Settled in Member
User avatar
Has thanked: 302 times
Been thanked: 103 times
it's going to be well worth it, can't wait to see how this turns out
_________________
https://www.etsy.com/uk/shop/TyremanWoo ... _shop_menu
 Profile
PostPosted: 05 Dec 2017, 19:56
Offline
Settled in Member
User avatar
Has thanked: 25 times
Been thanked: 34 times
Update will be coming in a few days - my work shifts have interfered recently #-o I make a point of NOT woodworking after a tiring shift, tiredness can too easily lead to mistakes or accidents.
Still, it's work wot pays for the hobby so, can't grumble too much :D
 Profile
PostPosted: 06 Dec 2017, 14:37
Offline
Settling In
I know the feeling nick, 15 years in and shift work still can screw me over!
 Profile
PostPosted: 06 Dec 2017, 15:49
Offline
Prolific Contributor
Has thanked: 602 times
Been thanked: 1013 times
I did eleven years of nights, seven on seven off - it's a killer.
 Profile
PostPosted: 06 Dec 2017, 16:26
Offline
Settled in Member
User avatar
Managed a slightly earlier finish today so made a start on the aprons - four lengths of 145x45mm PAR/PSE needed to come down to 40mm depth so, having practiced my hand planing abilities on the bench top, thought this would be an ideal opportunity to try out the easier option, a planer thicknesser. Went very well, nice smooth and square finish, just a once over with a smoothing plane should finish the surface nicely.
Next job: laminating two and two of these apron boards to get two finished width boards of c. 290mm - then the legs and rails and the job I'm half dreading and half looking forward to, mortise and tenoning them (which will be my first ever proper attempt at this joint :shock: )
 Profile
PostPosted: 12 Dec 2017, 18:31
Offline
Settled in Member
User avatar
Quick progress report:
Planing, squaring and laminating the two boards for each apron.
The two c. 2 metre lengths of timber for the bench legs before starting work on them.
More planing and squaring up after cutting the legs to their final length of 875mm / 34 3/8 inches.
Next - mortising the legs by hand - debating whether to use the drill press to make the initial holes, or to do it completely by hand with a chisel.
I'm not rushing partly because of work but also the Workbench series of videos is only one every two weeks and Episode 4 of 9 is this coming Friday.
 Profile
PostPosted: 12 Dec 2017, 19:56
Offline
Settled in Member
User avatar
Nice! The mortises aren’t so bad, you get into the rhythm of it quite quickly and you soon see improvements to your technique etc. I actually found cutting the tenons to be trickier as they’re so damn big.
 Profile
PostPosted: 12 Dec 2017, 20:20
Offline
Valued Contributor
Has thanked: 1 time
Been thanked: 83 times
NickN wrote:
........the Workbench series of videos is only one every two weeks and Episode 4 of 9 is this coming Friday.
Huh? How come I was able to flick through the whole lot to 8 of 9 last week, to see what people were talking about? I only didn't see the 9th because it was dinner time.
_________________
Slope Immune
How to build a shed properly: here
 Profile
PostPosted: 12 Dec 2017, 21:41
Offline
Settled in Member
User avatar
Encouraging to hear that - I'll probably make a start tomorrow!
I think what you're referring to is the Mk1 or original series of nine episodes titled 'how to build a workbench'. The new series is titled 'how to make a workbench' and is a revised design, on Youtube there's only two episodes so far, Woodworking Masterclass site has three episodes published.
 Profile
PostPosted: 12 Dec 2017, 22:18
Offline
Good to know Mr. Sellers is the same as the rest of us and makes a better second bench. :D
 Profile
PostPosted: 13 Dec 2017, 11:35
Offline
Settled in Member
User avatar
Has thanked: 12 times
Been thanked: 17 times
NickN wrote:
the new version is rounded 2 x 3 - quite why I don't know but can guess that it might be a combination of keeping weight reasonable, costs lower and possibly also with the new way of tongue and grooving the well board into the bench top the old version had too much depth.
Round-edged 3x2 is more commonly available to 'the average hobby woodworker' somewhere like B&Q, Homebase, etc. Paul even had a quick c amera-phone video up of him going into Homebase(?) and showing off some deals on wood they were stocking at the time, which would be ideal for his workbenches.
However, this wood he has here was actually picked up from the Oxford Wood Recycling centre, which is why some boards have scrapes and holes through them. Half of it was off the racks/shelves and half of it he picked up in a clearance batch of 50 lengths for £1 each... lucky lad. I went up there and they seemed very short on stock.
But yeah, Paul is basically opting for videos that better represent the average hobby woodworker, their available resources and their typical working space... based on surveys of his subscriber base.
This is why he ditched the professional Master Woodworker appearance with all those tool cabinets and a choice of 50 planes, and now has a pseudo-garage space with a fake brick backdrop, and everything is geared around smaller workshops and minimal tools. He has a couple of blogs about it.
Makes some sense, I suppose.
If it's being done in his back garden, that's Bench mkI.
If it has a brick background, that's Bench mkII.
 Profile
PostPosted: 14 Dec 2017, 13:45
Offline
Settled in Member
User avatar
So, I thought it would be as well to get the rail boards sized and planed to final dimensions before cutting the mortises, in case of any unforeseen problems.
I've also disovered that this would be a good point for a modification to the design, but I'd welcome opinion too. The original design calls for 18mm thick tenons (on a 40m thick rail) into legs that are 95mm wide.
Seems (and looks) to me that the tenon is a bit thin into that size of leg, so my proposed change is to make the tenon 24mm thick (on a 42mm thick rail) into legs that, in my case are 92mm wide.
Or in other words, the tenons will be slightly over half of the rail thickness and about quarter of the leg thickness, seems like about the best compromise, and matches my chisel size.
Cutting the rails to length.
 Profile
PostPosted: 14 Dec 2017, 13:53
Offline
If you are to make the tenon half the thickness of the rail you could save some work by making it with single shoulder.You just need to take a little more care when cramping up.
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google Feedfetcher and 7 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Dubuque clamps and the cheap 'Paul Sellers' clamps
in Buying Advice | Tool Reviews
Bodgers
7
412
07 Nov 2017, 10:10
Workbench Build
in Projects, workshop tours and past mistakes
Fitzroy
6
951
27 May 2017, 09:46
Workbench build
in General Woodworking
Eskimoernie
7
676
27 Mar 2017, 12:14
Prototype workbench build - WIP
MattRoberts
36
1224
04 Jan 2018, 20:30
English Workbench Build
nabs
163
7920
15 Jul 2017, 19:37
cron
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
