UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: 08 Jan 2018, 16:35
Offline
Settled in Member
User avatar
Has thanked: 63 times
Been thanked: 55 times
NazNomad wrote:
I should add a few notes about the photo of mine from above...
Inside is a copper t-piece with lengths of copper pipe about 1ft long, drilled with little holes along the top surface.
I assumed this would displace the steam more quickly and evenly around the wooden box. Now, when you open the box, it's pretty damn foggy in there, but I honestly have no idea if the pipework inside makes it better/quicker/easier or not, I never tried a 'before' test without it.
In the sides, along the joint of the two pieces of wood, I banged a row of 3'' nails (one row on either side) to support the wood during the steaming process.
Worth noting that where the wood rested on the nails, it did mark the timber I was steaming (not a problem for me as the marks almost sanded out and were inside an instrument with a tiny soundhole anyway, never to be seen again).
Next time I use it, I'll replace the nails with small dowels or bamboo skewers.
Again, I assumed raising my piece of timber off the bottom of the steam box would be ''more better'' and I had to do it anyway because of the copper pipe I'd installed in there.
My steam generator: Nothing I would improve or change there, it worked perfectly. Gas burner / pressure cooker with the valve removed / washing machine hose.
There's a washing machine tap visible, I installed it to keep the steam out of the box until it was properly mental boiling, Again, I have no idea if it's necessary.
Just a few notes from having been there, done that. Albeit infrequently.
Try it, if it ain't working then try summat else, it's all a laugh, innit?
Oooh, important addendum: Don't write 'THAT' on it if you have children that use the internet. 8)
Nice. Thanks for the info. How long is the box?
 Profile
PostPosted: 08 Jan 2018, 16:56
Offline
Valued Contributor
Has thanked: 1053 times
Been thanked: 640 times
As long as a pallet... I have no shame.
_________________
It looks extremely dangerous and may attack and explode at any time... WE MUST DEAL WITH IT.
 Profile
PostPosted: 08 Jan 2018, 17:01
Offline
Valued Contributor
Claymore wrote:
... what did you bend the wood for?
Amongst other, smaller things, I bent the side for this Langspil.
I suspect most people have never heard of a Langspil (I hadn't, until I had?)- https://en.wikipedia.org/wiki/Langspil
_________________
 Profile
PostPosted: 08 Jan 2018, 22:19
Offline
Settled in Member
Has thanked: 4 times
Been thanked: 8 times
Installing a steam ledge, I've used 10mm dowels along the sides. So I've got two dowel ramps allowing me to place up to 2 inch stock thickness, on two levels.
I thought about a pipework gallery to distribute the steam, but will we how I go when I first raise some steam.
As I have the same space issue in my workshop, when not in use, it will be kept wrapped up behind my shed. As I've used latch its a pretty durable material.
 Profile
PostPosted: 08 Jan 2018, 22:28
Offline
Valued Contributor
Don't forget some decent gloves, that wood get frikkin' hot in there. :-D
... and make sure you are all set up and ''ready to bend'' as soon as it comes out of the steamer.
_________________
 Profile
PostPosted: 09 Jan 2018, 09:25
Offline
Settling In
Has thanked: 8 times
Been thanked: 18 times
What's the pressure cooker capacity versus steaming time required ratio like? I know the wall paper steamers fairly chew through water but they switch off automatically when they run dry.
I presume you need to rely on the noise the cooker is making?
This is all fascinating as it's on the to do list of experiments for this year.
 Profile
PostPosted: 10 Jan 2018, 19:53
Offline
Settled in Member
Test steam today, some small mods to do but its worked well and sustains 100 degrees steam. Thanks for all the feedback. See some photos[attachment below
 Profile
PostPosted: 10 Jan 2018, 19:58
Offline
Valued Contributor
User avatar
Has thanked: 1145 times
Been thanked: 512 times
Excellent Naz and I have seen one before at a Shetland Viking festival in the 80's a load of us hairy bikers paid them a visit and they had some great musicians play all sorts of strange objects :D had a great time and even managed to pull a viking wench :lol:
Brian
_________________
My Photos
https://www.flickr.com/photos/39613787@N05/
https://www.flickr.com/photos/gallowayintarsia/
Scroll Saws
Axminster Trade Series AWFS18
Axminster Trade Series EX-30
Bonsai Tree Lumberjack/Tree Surgeon
Ex Professional Bull Rider
Medical marvel wooden legs with real feet
 Profile
PostPosted: 10 Jan 2018, 19:59
Offline
Settled in Member
Condensate diverter (with silicone) and barbecue thermometer, idea from web.
 Profile
PostPosted: 10 Jan 2018, 20:11
Offline
Settled in Member
User avatar
Awesome! What were you bending
 Profile
PostPosted: 11 Jan 2018, 22:21
Offline
Settled in Member
Blackthorn, hazel, hawthorne and ash.
 Profile
PostPosted: 12 Jan 2018, 19:30
Offline
Settled in Member
User avatar
Post pics!
 Profile
PostPosted: 12 Jan 2018, 19:43
Offline
Valued Contributor
Good idea with the condensate diverter, mine just pished out through all the gaps :-D
... and as above, pics of what you're making would top it off nicely.
_________________
 Profile
PostPosted: 12 Jan 2018, 19:48
Offline
A Regular Member
User avatar
Has thanked: 55 times
Been thanked: 113 times
+1 for pictures (or even better a WIP) :D
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 0 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
SOLD Mirka Abranet 150mm P120 X10
in For Sale
YorkshireMartin
2
741
01 Nov 2017, 19:08
Long screwdriver bits (6"/150mm) and bit sets?
in Buying Advice | Tool Reviews
Eric The Viking
6
404
05 Feb 2017, 12:46
How to build a real steam locomotive
in General Chat (Off-Topic)
devonwoody
12
744
20 Aug 2017, 09:31
Milling Machine for Steam Engines
in General Metalworking
Rhyolith
44
1655
02 Nov 2017, 17:59
Pipe Clamps
Lonsdale73
6
458
05 Mar 2017, 09:42
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
