 Reply
User avatar
By Tasky
#1217340
I've messed about with a couple of design packages before.
Problem is, it takes so long to make something up and you're tied to the desktop PC, pretty much. All that time spent designing and aligning everything in virtual just means I'm not making anything.
I started carrying little Molleskine notebooks way back when I was working in leather, because my best ideas and solutions usually occur when I'm out and about, at work or otherwise away from my home PC. It's also far quicker to make quick sketches, make alterations or additions, and refine them into nice pretty 3D pencilled artwork later on... if they're even needed.
TBH, half the stuff I make doesn't need a detailed design sketch anyway. Maybe a few angle measurements and dimensions, a couple of reminder notes for when I come to do the work, and that's about it.
By John15
#1217351
For a piece of furniture with a simple design like a table, at most you need a plan, and front and side elevations, plus a detail of the leg/rail joint. This is so easy and quick with pencil and paper as AndyT has said, I'd have thought hardly worth getting the computer out. For much more complicated pieces I can see the benefit of Sketch-up or CAD.
By Fergal
#1217381
I find Sketchup handy for visualising how something will look in its final location and getting proportions right. For example I once used it to design some under-stairs cupboards so that I could see if the doors would open without fouling anything.
I also used it to layout an ensuite shower room in a loft conversion. By putting a model of a person in the room, I could see if there was enough headroom allowing for the slope of the ceiling.
When designing small items, it is useful to be able to print them out actual size as templates etc.
I've recently been trying Fusion 360 which is considerably more powerful and consequently much harder to learn. Its main advantage is that it is parametric so that you could, for example, design a shelving unit of a certain height with an arbitrary number of shelves which would be equally spaced. By changing the number of shelves required, the program would automatically recalculate everything for you.
Fergal
By Beau
#1217540
I use whatever I feel is needed for the job. Sometimes a sketch on and old envelope and do the rest in your head. SU is nice for complicated joints and seeing in 3D how something is going together. Also I am poor at drawing for the customer and SU works well for this but if I could draw well would not use it for this. Favourite when possible is a rod which is a full size plans on a sheet of ply.
User avatar
By Woodmonkey
#1217589
Fergal
Sketchup can do this.
By Yojevol
#1217598
Woodmonkey wrote:
Fergal
Fusion360 at $360/year?
By Grawschbags
#1217600
I have been teaching myself sketchup whilst designing a router table. I roughed it out with pen and paper, then took it to sketchup. It's probably already saved me the cost of some materials given that I could see issues in my design before cutting anything...
User avatar
By MikeK
#1217662
Yojevol wrote:Fusion360 at $360/year?
From the Autodesk website, Fusion 360 is free to hobbyists and startup businesses that have less than $100K in gross revenue. The free subscription must be renewed each year for as long as Autodesk supports the generous offer.
https://www.autodesk.com/products/fusion-360/free-trial
User avatar
By Eric The Viking
#1217875
Grawschbags wrote:I have been teaching myself sketchup whilst designing a router table. I roughed it out with pen and paper, then took it to sketchup. It's probably already saved me the cost of some materials given that I could see issues in my design before cutting anything...
Exactly the same for me - SketchUp lets me test designs before diving in, saving both mistakes and materials.
For example, I had a shock recently when I realised that for the interior doors I'm planning to make, I can save about seven feet of stock by using dominoes instead of traditional mortice and tenon joints. That's per door, and I have a dozen of them to make. It means the dominoes will pay for themselves and the construction will be much simpler as a consequence. Of course, if I was more experienced I'd know this already (and I'd already have a story stick, too), but I'm not. Seeing it as 3D objects really helped in construction decisions.
Of course I rough stuff out with pencil and paper (weapon of choice is a 3B or 4B pencil), but my measurements come from SU, as do the plans usually, and I can quickly get sections through a 3D object, to see if there are issues such as clearances that will cause problems.
Two more recent examples:
I've got to make a strong storage box for castoring legs for a tower scaffold system. These things are three feet long (roughly), very unbalanced (weight at one end), tubular and greasy. But they are also fragile and a safety-critical component. And I need space to store small parts for the toeboard brackets, etc. I won't be using it - it belongs to the church my wife attends - so things have to pack-in intuitively. So I've drawn out a castor column to scale, and copied it four times. These objects I can just move around in 3D until I get a practical arrangement.
I'm refurbishing a motorbike fuel tank, by stripping paint and rust from the inside and re-coating it. It's big and will be pretty heavy when it's full of chemicals. I'm making a jig to hold it, allowing it to rotate for agitation and invert for draining out. I can't afford to drop it (no dents presently) nor splash chemicals on the outer paint finish. So again, modelling it and the jig lets me see if ideas will work.
I've also played with drill press table designs, etc. Again, I picked up on problems where the quill three-handled drive would foul parts of the table, and issues fixing it to the press's existing circular table, for which I think I now have a neat solution.
I could do all of this without SU, but nowadays it's my go-to aid for thinking through design problems.
The biggest tip I was given, incidentally, is to make every object you create a "component", as soon as you draw it out - cubes, cylinders, whatever. That way you can control how they interact with other parts of the model (you can always combine them later on). The ability to have clones of a component, such that changing one modifies all of them at the same time, is invaluable for things like table legs and other repeated components in a design. I use that a great deal too - it's automatic and very fast. Again you can turn this off quickly if you need to.
HTH, E.
User avatar
By woodbloke66
#1241994
DTR wrote:A sketch on the back of an envelope works for me.
On occasion I've done a scale drawing, usually when there's funny angles involved. An old roll of wallpaper is quite handy for drawing on; I got a roll for 25p from B&Q (or Homebase?) when they were getting rid of stock.
Generally I agree with this approach as I just can't be faffed with SketchUp. Over the last couple of years I've created several boards on Pinterest of stuff that interests me and it's from this that I get most of my inspiration and ideas for new projects. Any new project is sketched out in a drawing book from Poundland and further details can be drawn approx. to scale on squared paper, available from WHS.
I then make a 1:2 or 1:5 scale drawing(s) on white wallpaper lining paper (cheap as chips but buy the lightest grade) which you can get from any of the DIY sheds - Rob
User avatar
By Jacob
#1242003
Pencil, T square, set square, A1 drawing board. Sketch pads backs of envelopes etc.
Sometimes paint a bit of hardboard with white emulsion for big full size drawings.
MFC shelving for rods.
You can't do rods with Sketchup or a computer unless you have a plotting printer. Even then it's just paper- better on a board so you can lay stuff on.
User avatar
By MikeG.
#1242034
Well, I've been an Autocad* man for getting on for 20 years, so I find myself diverted to drawing furniture or somesuch when I'm bored working. I am quite happy sketching on a scrap of mdf or the back of an envelope, though, and have done some pretty substantial pieces of furniture without any formal drawing.
*Draftsight for the last year or so. It's excellent, it's free, and it took me less than 2 days to teach myself.
The following is the real benefit of drawing on the computer, rather than at a drawing board, in my view. This is a series of sketches of alternative pedestal designs for a dining table I am planning for next year. It takes seconds to copy a design across and alter it, so that you have side-by-side comparisons, and can make an informed choice from a dozen or more alternatives:
