 Reply
User avatar
By Celtic Eagle
#512202
Hi
First post and maybe a daft question but can anyone explain how to sharpen a spokeshave and set one up correctly? I have been buying secondhand tools and picked a decent spokeshave up but it's blunt and not set correctly.
Any advice appreciated
User avatar
By Jacob
#512207
If you mean a steel one with a squarish flat blade then honing is much easier with a blade holder - a saw kerf in a short length of 2x3/4" will do it.
You can do something similar with a trad blade and work it diagonally along the stone - though you might need to undercut it so that the bottom "jaw" clears the stone.
Setting up is just a matter of trial and error.
User avatar
By matthewwh
#512238
A piece of thin paper under the nose sometimes helps for setting the blade, just drop it into place, tighten everything up and you should have a nice fine set. Some people set the blade for a heavier cut on one side so that they can vary the thickness of shaving by using different parts of the blade.
It will soon click if you spend a little time playing.
User avatar
By jimi43
#512243
I put my index finger under the mouth to hold the blade and then tighten...
I got the feel for it now and know exactly the depth I need...
My lightbulb moment however came when I switched to a Vertias blade...(iron)....
To make it fit...file down the bed not the mouth...that way you get a nice seating and it pokes through...just!
Word of warning though...this upgrade can seriously increase your pretty shaving count!
:wink:
Jim
User avatar
By Celtic Eagle
#512797
Thanks Guys
Guess what I'm doing tonight
User avatar
By jimi43
#512811
Celtic Eagle wrote:Thanks Guys
Don't forget CE....pictures...we love pictures!
Just a bit of encouragement for you...my No.52 "Veritas" shave came out in anger the other day...a bit of homegrown cherry needed shaping:
This iron in the modified No.52 really zips along...
...resulting in a "veritable" wig's worth of spiral shavings....
....and a fine finish....
Good luck with your tuning!
Jim
