UKWorkshop Woodworking Forums
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: 13 Dec 2017, 03:35
Online
Valued Contributor
Has thanked: 30 times
Been thanked: 217 times
:mrgreen: One thought, these things are heavy do you need to move it around in the workshop, or will it stay in one place, worth thinking about before it arrives, RP offer a wheel kit at £59.99 if bought at the same time, there is no image of it, but I assume its the same as the other full height units i.e. two wheels at the back and a jack handle with wheels, if its a replacement for the cabinet and is the same as the push down version, don't bother its horrible, better to make your own box and put some lockable castors on the bottom.
Mike
_________________
"Sent from my laptop using all my fingers"
 Profile
PostPosted: 13 Dec 2017, 09:49
Offline
Settled in Member
User avatar
Has thanked: 26 times
Been thanked: 35 times
A very good point Mike, luckily one I have been thinking about already and have been in touch with Peter at New Brit Workshop about his low profile castor carriage that he built for a planer thicknesser - so the plan is to build a modified version of this (with the castor beams at front and back to allow for the side opening lower cabinet door on the bandsaw). As the bandsaw table is quite high enough already the less added to the height by castors the better, really.
The added advantage of building my own is that I can make it a fair bit larger than the base footprint, improving the stability a bit.
However... I would be interested to know what people's experience of the RP full height wheel kit is (the one with the jack handle at front)? Looks like the castors at back don't swivel so that could be a nuisance.
 Profile
PostPosted: 13 Dec 2017, 11:26
Online
Valued Contributor
Peter's low profile carriage seems ideal, allows you to move in any direction, the non swivelling castors on the Record Power base's are a nightmare and drove me up the proverbial wall, they had to go, the rest of the unit for the 350 is to say the least of a lightweight construction, if you move your bandsaw a lot the wheels eventually distort to such an extent it will not work anymore, the wheels are mounted on a cantilever piece of metal that bends and puts all the careful adjustments made to make the unit work a waste of time.
Pic shows the original RP castors, the fixings are one bolt only each end onto a cantilever, very bad design, you can see the distortion of the sides.
Mike
_________________
 Profile
PostPosted: 24 Dec 2017, 10:56
Offline
Participant
Has thanked: 0 time
Been thanked: 0 time
I for one will be very interested in what you think of the bandsaw after you've lived with it for a while.
For the money, it's does seem to be up there with the best.
 Profile
PostPosted: 24 Dec 2017, 11:59
Online
Valued Contributor
One of the nice touches I noticed was the allen key holder on the tower, at the moment mine are on magnets, but the holder is a much neater arrangement, will ask RP if they are available as an accessory.
Mike :ho2
Just thought, get a nice piece of oak, drill it for the allen wrenches and epoxy some magnets into the back of it, job done.
Merry Christmas to one and all. :ho2 :ho2 :ho2
_________________
 Profile
PostPosted: 08 Jan 2018, 11:07
Offline
Settled in Member
User avatar
A very large and VERY HEAVY (150kg) box arrived today - luckily the pallet delivery driver was a helpful chap and we carried the box, just, into my shed, where it now sits awaiting unwrapping.
I think I'll video it in case anyone is interested? Charging camera batteries up now.
Once I get it unpacked I'll measure the base unit and make a castor trolley before getting it properly set up.
 Profile
PostPosted: 08 Jan 2018, 11:53
Online
Valued Contributor
I think we are all interested in this new departure for Record Power, they sound as though these should be the new standard for current Bandsaw's.
Keep us informed.
Mike
_________________
 Profile
PostPosted: 12 Jan 2018, 20:53
Offline
Participant
Has thanked: 2 times
Been thanked: 1 time
So what do we think about the Sabre 450?
The spec looks good. Yandles Web site says “Available”, although this might mean “to order” rather than “in stock”. I’m tempted to drop in when I drive past Yeovil on Monday.
 Profile
PostPosted: 12 Jan 2018, 21:18
Offline
Regular Contributor
User avatar
Has thanked: 231 times
Been thanked: 204 times
I took a good look at a Sabre 450 before Christmas and for the price it looks very impressive. I have not used one and the showroom one was not powered up but it has some good features.
I thought the guide bearings looked easy to set up and well thought out both above and below the table. The upper blade guard trunnion was well engineered moving smoothly. The top wheel looked solid with good adjustments for both tension and tracking.
I think my biggest concern was the new fashion of blade guarding and long slots for blade changing, getting a blade on and off the machine may need three hands. The fence easy adjustment for drift would cause problems in a teaching workshop, I just know it would be accidentally be adjusted all the time.
It will be interesting to see how this new bit of kit stands the test of time but things are looking very promising for RP. I feel they have gone through a cheap period of manufacturing but are heading in the right direction. If they can keep upping their game when so many are heading the other way they should do well.
Cheers Peter
_________________
Peter Sefton
Practice makes perfect - but a good tip from one who knows saves timber, time and tools
http://www.peterseftonfurnitureschool.com
http://www.woodworkersworkshop.co.uk
https://www.facebook.com/woodworkersworkshop/
 Profile
PostPosted: 13 Jan 2018, 06:50
Offline
Settled in Member
Has thanked: 1 time
Been thanked: 54 times
Roland - I was at Yandles last weekend, they had a Sabre 450 on display to have a good look over so would be worth you dropping in I suggest.
Sent from my SM-N910F using Tapatalk
 Profile
PostPosted: 13 Jan 2018, 10:43
Offline
Settled in Member
User avatar
I hadn't planned on posting this until I got the thing up and running, but as getting the castors and wood for my castor platform has taken longer than expected, I may as well put the link here so anyone interested can at least see the build of the Sabre 350 close-up, even if not actually fully assembled or running yet.
https://www.youtube.com/watch?v=kcTURPMzbnU
So far, impressions very favourable, and that includes the excellent instruction manual which, after years of having got used to badly photographed badly printed manuals with instructions to "Thank you for buy our easy to installation product, we invite you cherish to care it, and to prevent injured, only battery assigns care on the charge", is a breath of fresh air.
 Profile
PostPosted: 13 Jan 2018, 18:25
Offline
Settling In
Has thanked: 18 times
Been thanked: 15 times
Duplicate post
 Profile
PostPosted: 13 Jan 2018, 18:26
Offline
Settling In
When I bought my 300E the guy in the shop advised that I cut it out of the box as you have done then chock up the bottom of the bandsaw off the floor on blocks. You can then attach the legs/base easily without fully tightening any screws. Once its all assembled you can finish tighten all the base nuts and bolts. It's then a simple matter to just tip the bandsaw up onto its base. This saves assembling the base separately and trying to lift the heavy bandsaw onto the base only to find holes don't line up correctly.
This method worked well for me.
Enjoy your new bandsaw!
HTH
-Neil
 Profile
PostPosted: 14 Jan 2018, 10:54
Offline
Participant
User avatar
Has thanked: 7 times
Great video on youtube. I am currently looking to upgrade my current bandsaw, so I am following your posts regarding the sabre bandsaw with interest.
 Profile
PostPosted: Yesterday, 02:25
Offline
Settled in Member
User avatar
Well, after a busy few days, Part 2 of my Sabre 350 unboxing and assembly is ready for viewing. The video starts with building of the base cabinet, followed by the custom castor trolley (similar to a New Brit Workshop design) and then assembly of the saw including table fitting, rip fence rail, handles, etc.
https://www.youtube.com/watch?v=ZjSaueEN3vQ
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Yahoo [Bot] and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
 Similar topics   Author   Replies   Views   Last post
Record Power BS12 Bandsaw
in For Sale
Roughcut
5
1054
26 Oct 2017, 16:25
(SOLD) Record Power BS350S Bandsaw
in For Sale
chris_d
5
542
01 Jan 2018, 19:28
Axminster Rip Fence Upgrade for Record Power BS350S Bandsaw
in Buying Advice | Tool Reviews
MikeK
28
2203
16 Apr 2017, 20:58
Record Power CL3
in Wood Turning - Lathes
bussy
2
251
04 Jan 2018, 19:32
Record Power Extractor
evoman76
9
738
18 May 2017, 15:40
cron
Register UKW
User Tools
UKW Local
Quickly find the nearest tool suppliers & timber merchants in your area
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
UKW Terms & Privacy
