Why use farrow and ball paint
ColeyS1
2 Nov 2009
Doing a recent job and a customer specified using farrow and ball paint. Think its the first time ive used it and hopefully won't have to use it again. The easiest way to describe it is its a bit like antivandal paint - it never seems to dry thoroughly enough to rub down between coats
I tried leaving it around 3 -4 days between coats and it still clogs up sandpaper like a goodun.
I used farrow and ball colour on my bench but got dulux to mix it, it seemed to level out alot better and was defo easier to denib between coats.
Is it just the colours that make this paint appealing ?
I've given the one on the left 2 top coats and it still needs another cause it looks a bit patchy :mad:
Pee'd right off using it to be honest
Coley
Sent from my GT-I9300 using Tapatalk
I have a few tins of f & B eggshell oil but once they are used up I wont get no more. It is very fiddly to use, needs cutting with turpentine otherwise its too clumpy and stiff. It starts to dry very fast which means it doesnt work out nicely and easily, even with a decent quality brush (I used purdey's). Personally I havent had any trouble with it staying soft for more than a day except recently on a table frame. But I suspect that was because I painted it out in the workshop. It was still soft and tacky after 2 days, no good to apply 2nd coat. But when I brought it indoors into a warmer atmosphere it recovered fine. I have had the best results using zinsserr 123 primer on new wood. I painted some kitchen doors (using a small roller) whichh worked fine. That was over a polyuthrane ikeaa finish.
I have tried craig & rose acryliic eggshell, way easier to use, covers superbly, like smooth creamy yoghurt. Some nice colours too.
That does make an interesting read. Do you think they might have made a massive quantity and somehow forgot to add the bit that makes it dry ? Took the best part of 4 hours and loads of sandpaper to get it ready to what i thought would have been the last coat.
Having stuff mixed would be the best option but what if they wanted something else made to match a few years down the line.
Excellent read, thanks, Roger and sums up my own experience of F&B. I do also know that if the paint is put on too thick then it forms a skin on the surface and this stops the underlying paint drying out. I am not a great fan of F&B since they went all eco-friendly and understand that other manufacturers (Morrells?) can mix up to match F&B colours.
Zinsser primer is the DB's. I won't use anything else now.
We are using some F&B at the moment on some cabinets I just finished making. The outside of the cabinets are finishing fine but the interior which is a red colour Radicchio No 96 is just not drying and the finish is very poor. I do like the colours they make but have also had problems before on some windows I made, the paint looked great but only lasted 1 or 2 years max before needing major repainting. Will be seriously thinking before using it again.
Peter
The inside of the cabinets must look identical in colour to these then ;)
Its a shame cause it was quite an enjoyable job before the painting began.
A guy came in the shop and wanted to borrow a length of 4x2. He touched the edge of the bookcase so gently with the end ( didn't even notice he did it ) and when I went to look I noticed 4 inchs of the edge completely back to the primer colour. I dread to think how it might look a few years down the line. Hopefully it can be carried in without causing any damage :|
When I was going through sandpaper after sandpaper denibbing, for some strange reason I kept on thinking to get some talcum powder to sprinkle on the sandpaper first. Have I completely dreamt that :?
Coley
I thought I'd read it somewhere but may have dreamt it :D can I be cheeky and ask for a bit more info on the cupboard that's painted on the inside ? Sounds interesting ;)
Colour men to the middle classes...
Lots of sensible people buy their colour chart, and get the local Dulux centre to mix it up :lol: :lol: :lol:
BugBear
Sorry it's not that interesting red on the inside and a green on the outside looks better than it sounds.
Cheers Peter
BugBear
I have had the local guys mix up Dulux to F&B ral colours, I think Dulux is a better paint but they just don't look the same :!: much is the pity :(
Cheers Peter
Sounds interesting ;) I made a wardrobe for home and wanted ash coloured mdf on the inside but stained mdf on the outside. It really made me scratch my head trying to figure out how to stop the stain colouring the bits I wanted leaving natural colour. I was thinking your painter may have had some tricks up his sleeve where the two colours meet :geek:
I'm trying to learn spraying and find im spending as much time thinking about how im gonna spray the thing and assembling it as I am making it :roll:
Coley
A job that's ideal for a spray gun. Mask off the bits you want natural ensuring the edge or corner where the break is to occur is masked off with masking tape firmly pressed down.
Mix some spirit dye with lacquer thinner, or alcohol, and fill your spray gun. Choke down the air pressure a bit and mist the dye on. Don't get the surface too wet so that the dye flashes off quickly-- this prevents the colour bleeding under the edge of the masking tape. Keep building up the colour until you get the result you want. After that you can remove the masking and apply your clear coats. The finish on the front of this cabinet was achieved using a similar technique to what I've just described. Slainte.
You make that sound so simple ! Cabinet looks fantastic by the way ;)
I've only ever brushed or ragged on the stain cause I've been too scared to spray it. What ratio thinners to stain would you say you mix ?
Coley
I just tend to sloppily do the proportions, but I think they're usually something 25% to 35% dye and the rest is lacquer thinner (aka cellulose thinners). I use this solvent in preference to alcohol because it flashes off quicker.
Incidentally, the tambour in that cabinet is dyed rather than stained, and there's a description of the colouring up procedure along with, for this thread anyway, extraneous discussion of tambour manufacture at this link. Slainte.
ColeyS1 once your confident enough to spray then using a tinted Precatalysed or harder wearing Acid Catalyst lacquer is the way to go. These lacquers can be matched to Farrow & Ball, Dulux, BS, RAL, Pantone shades (naming just a few) and are far more durable, cost effective and easier to spray than paint.
Hope this is of assistance.
I agree but for many of us the luxury of a dedicated spraying area/spray booth is just that... a luxury.
That's good to know, my concern still remains with the customer asking for a matching piece of furniture 3 years down the line. Is the scanning and mixing technology there to be able to order 'the same' but years apart?
An example was I took a glossy lego head into b and q to be colour matched. Just before the guy was about to start mixing he got me to take a quick look at the screen. Compared to what I was after it looked orange :shock: Another chap who had heard what had happened, came over when I was looking at a colour chart instead. He reckoned he struggled getting them to match stuff and went to Brewers instead. This is all a bit he said she said but went on to explain that b and q's machine uses some kind of red laser beam to scan the surface, meaning on anything shiny the colour often had a red tinge :? I can't see why the guy would have had any reason to lie, and it certainly explained the scanning yellow but ending up with orange situation.
Fifth and final coat of paint last night - moved it earlier out the way, now got nice finger marks to touch up. I'll never use the paint ever again as much as I like the colours. I bought some 'little greene paint' in error a while ago so will be experimenting with that to see how easy it is to apply, denib and most importantly ruddy dry and be durable. I'll have a load of freestanding furniture to make myself very soon for myself so would like to find some heritagey colours that actually perform as they should.
Coley
