Kalimna
- Joined
- 18 Nov 2009
- Messages
- 1,275
- Reaction score
- 1
Jacob - sorry to be the geological era pedant here, but it is highly unlikely that stropping was around in the paleolithic. Twas only stone tools then - not sure how you would go about stropping a flint axe.
On another point, your arkansas stone may be 'surgical' grade, but it will produce an edge not nearly fine enough for a surgical tool in the modern era. What may have been appropriate and acceptable in antiquity (surgical or woodwork - the line blurs somewhat!) has now been superseded by modern techniques (laser cut for scalpel blades, I think), if it was good enough a couple of hundred years ago, that is only because there was nothing better at the time.
I do appreciate your experience, and pragmatic approach to woodworking, but it really would be nice and make a pleasant change if you appreciated that yours isnt the only acceptable way of doing things, and some folk have different reasons for doing woodwork the way they do.
A maxim (or is that axiom?) I use at work - 'If there truly was only one good way of doing things, then everyone would be doing it without exception'.
Cheers,
Adam
Cheers,
Adam
