Do you have 220 volt Three (3) PH supplies available in Denmark?
If not and you are changing the MOTOR links within the motor connection box to Delta Connection 220 Volt for use with a single phase to three phase Invertor to run on domestic 220 volt single phase supply then the existing 400 volt three phase Start Stop switch will be become redundant anyway.
