powertools
Racers":3l3ufn4t said:Jimson":3l3ufn4t said:I do, and it's my first post. Perhaps I don't get the joke yet ...
Anyway, if anyone can help - I want to re-grind the primary angles on some bevel edged chisels and a couple of plane irons to 25 degrees. I haven't been able to do it myself even with the coarsest papers and have made a bit of a mess of them. There's a local service which will do them using a surface grinder. Is this likely to overheat and damage the steel in the chisels and plane irons? The man at the shop said he would do it without taking much off and so thought he could do them without damage, but I'm not so sure. Any advice much appreciated. Many thanks.
Get the coarsest paper you can find stretch it tight I use clamps to clamp it down and others to pull the clamps apart.
Stick the blade in a honing guide and have at it, check the temprature of the blade as you can build up some heat
This is my set up used for cleaning shoulder plane sides but it works for blades.
DSC_0054 by Racers, on Flickr
All due respect to you for posting a photo of your bench that is in the same state that most of us have.
