Mark Merrifield
New member
Hi there, can anybody advise me on what lifting mechanisms are available. I'm making a round table with a chessboard set into the centre. I'd like to be able to flip the chessboard over so it can be hidden when not playing. Ideally, the mechanism will lift the board up, away from the table, then manually rotated and pushed down (or even better if all automated). If you have any info/links that would be very helpful!
Chessboard will be around 300mm square and about 20-25mm thick.
Thank you
Thank you
