CHJ
On the blade clearance when exiting a cut, could you work with a blade with increased kerf? this would give you more clearance.
One other thing, I've come across bandsaws having excessive front to back play in location of the wheels on the shaft, placing a suitable washer on the shaft behind or in front of the wheel has stopped the wheel from sliding along the shaft.
(fitting spacing washers does not alter or need shaft alignment changes) worth a check with blade released just in case.
