Jacob
Pint of bass, porkpie, and packet of crisps please
That's a good idea. I often use a blow lamp but I've got a little culinary one ( for singeing orange peel for cocktails etc.)rafezetter":2xgnfrj2 said:....- up to painted wood getting a lick from my small pencil torch (same size as a creme brulee caramelizer, coz that's what it is), .......
The main thing is to clean the slot/cross, use sharp fresh screwdriver and the magic trick is to tighten a click before you start to loosen - it breaks the seal and if it damages by camming out it doesn't matter as the other side of the slot for loosening will be undamaged so you've got a second chance and you know how tight it is.
Another thing is to have exactly the right screwdriver or bit. A slot needs a bit slightly less wide than the slot, so it doesn't ride up the countersunk sides of the hole.
A long screwdriver helps - it's easier to keep it straight and perpendicular to the screw head.
Brace and bit not good - if it needs that much force it'll break anyway.
