The TS200 slider is very similar to the TS250 which I have found to be excellent, took a long time to set up to be parallel to the table and the right height, but lots of adjustment available and in over three years it has not needed to be re-adjusted, the slider for the AC216TS looks a lot like the sliders for the larger table saws, only when someone has one will we know if its any good, but as Bodgers said, if you are looking to get a table saw with slider, I would look at a bigger saw.
