Jacob":3lt3oh2y said:Me no expert but tend to believe that a steel is best - it doesn't remove much metal if any but instead reshapes the edge.
Which is fine as long as the steel in the knife is soft enough.
Or the steel in the steel hard enough.phil.p":1ayebje9 said:Jacob":1ayebje9 said:Me no expert but tend to believe that a steel is best - it doesn't remove much metal if any but instead reshapes the edge.
Jacob":nnj4td7e said:Me no expert but tend to believe that a steel is best - it doesn't remove much metal if any but instead reshapes the edge.
It wouldn't matter if the steel was the hardest thing known to man - if the steel in the knife is too hard it won't forge cold. If you're not removing metal that's what you are doing.Jacob":2knl9u85 said:Or the steel in the steel hard enough.phil.p":2knl9u85 said:Jacob":2knl9u85 said:Me no expert but tend to believe that a steel is best - it doesn't remove much metal if any but instead reshapes the edge.
