Record 74 auto vice
nabs
24 Aug 2015
Herts
Having recently moved, I find myself without a workshop and with a long list of jobs to do around the house so it made a nice change to fit in a little bit of tool fiddling this weekend:
fVcha3Sh50VpQOG7odbB3SO0a_YNEf951JkGVt2gxXUlPfmjxqfRIi_v-pE=w2400
A record 74 vice - a bit grotty but in good condition, the only minor issue being that at some point the pin that retains the washer/spring used to hold the handle against the moveable jaw had broken and the washer bent as a result. Once extracted a few whacks with a hammer got it back into shape, and an old nail did as a replacement pin.
gwy9V9ghBjkK4PXvv3vV5diqqcsXtrh5aiI7cz59hYl-1JWEFAqsUL_2vDQ=w2400
Having got it apart a bit of elbow grease to remove 80 years of accumulated oil and grease plus various layers of paint (not sure why it was partly painted green - perhaps to distinguish it from others in a shared workshop?) and it looked like this:
gwvHLvkU6P4nvmVeoHahZJLRnRbTqkCJerOEojKEg_ymZEZ_EBEDdEezOZM=w2400
more thrills to come!
*edits to fix photos
we did cover this type of vice a while ago when discussing the excellent Record Imp (the smaller brother of the 74)
record-imp-vice-t23939-30.html
this version has the patent date on it so was made some time after the summer of 1929 and the late 1940s.
I am pleased to report that - as with all Record products of this era - the quality is excellent with very well finished castings and a substantial steel slide and screw.
There is an even larger version of this design (the model 75) which in its earliest incarnations was made completely of steel, but the 74 (and later versions of the 75) have a cast iron body.
It is simple to install - 1/2 inch hole through the worktop and secure underneath with the large nut and washer. Here it is installed:
8W-fcRm_BXJtdtAGfwg74IOObUYn9PIluzv4Ol888BzPLeWhRb76N6E01HLo=w2400
in the next instalment: all those Record 74 features you never knew you needed.
* edit to fix photos
Nice stuff Nick but only the first image shows up - have you set them all to Public?
hmm, I'm not really sure why one works and the others don't - will investigate!
Thanks Nick - nice job on the cleaning up, leaving it old but cared for, a look I like to cultivate myself, as I think do many woodworkers of a certain age...
Looking at your photos made me wonder what the square headed set screw was for. On re-reading your earlier posts I see it was for straightening valves, so I'm hoping that by now you have built up a stock of slightly bent valves needing remedial treatment and that some action shots are coming soon!
actually it is a set screw to hold the anvil in place - as you can see in the patent drawing below the anvil has a stud that is located in a hole on the upper surface of the fixed jaw and the screw pushes on that. In theory the anvil is detachable (I suppose for the manufacturers convenience, rather than ours?) but mine is stuck fast.
ZLt-vYbMMdFI_iq-Is2sfKOpd7ns93JR-pZQcGFKOy0LdOEqKITH0Q
Since Andy mentioned the valve holders, you can see them in this picture below the anvil. They consist of two holes of different sizes and according to the patent are
'adapted to support a valve stem of an internal combustion engine or for use in straightening bolts or rods'
I can (sort of) see how they might be used in straightening a rod (assuming it was only bent a the very tip!) - can someone more mechanically minded than me explain why you might want to insert an engine valve in there?
VbOUxNgev2b1qMT8YPxB-DoneVm_JvbKbkbfp8g2lCFE2wVcckgccNB7Er0=w2400
PS you can just see my Record Imp on the LHS for a size comparison - the imp has 2 1/2'' jaws and the 74 is 4''. not a very good picture I'm afraid!
engines of that age had soft steel valve stems, with hardened seats. if a valve spring or collet broke under load it was common for that valve stem to bend under the unusual pressures.
Hammering the soft valve stem back into the slot with a rawhide mallet on the valve face would allow the valve to be reused. I've seen some hammered straight on blocks of wood, just as you would straighten a bent nail for reuse.
Not exactly formula one , but back then any engine could be fixed in any local garage, instead of waiting for a new part to be shipped from japan or even china.
thanks to Bob we now know what the two holes are for on the fixed jaw. Other features include
pipe bender: this consists of the curved section at the base of the movable jaw and the vertically grooved lug opposite on the fixed jaw (see the picture above ). The pipe is gripped between the grooves of the two lugs and can be bent around the curved part.
The jaws are offset so as to not interfere with the pipe. In the earliest adverts the pipe bender is described as 'adjustable', but I have no idea what this refers to.
Incidentally, I actually used the pipe bender on my Record Imp to bend a metal brake tube in the summer - technically it would have been possible to do the same with my fingers, but I am sure I did a far better job thanks to our friends at Record!
hardened steel anvil (removable!) and beak (not removable!)
swivel base - the underside of the fixed jaw has two tabs which sit in the 9 pairs of notches in the triangular base - simply loosen the monkey nut lift the vice and twist to a new location.
the vices were supplied with two added extras:
fibre jaw grips for gripping delicate items (good luck finding a vice where these have not already been lost!)
Cylinder head holding plug (automotive related!): a hexagonal rod with two screw threads designed to insert into the threaded cylinder head holes that received the spark plugs (one for US plug thread and one UK). These have of course all been lost also.
Finally there was a pipe gripper - this consisted of a removable v-shaped metal part with a serrated edge that fits in a groove in the moveable jaw, below the grip. The casting on the other side is v shaped and has a slot which receives the other metal part allowing the vice to fully closed even when the removable part is installed. According to the patent the removable part was originally designed to be held in place by a set screw, but this is absent from the actual implementation. This no doubt explains why they were all immediately lost. It would be a simple job to make a replacement should you wish to loose your own.
OclSvvzLPeN6cqgpKp-p0v9Dw96zsDCUoGqkaCg4MxiYtCyypwVETA0-TfA=w2400
zD8mqLXkz9Y9VFjKO7kB6lzYqTZv0vNEdcXMcDtxSpC5ljpy0CG1zq7iv-E=w2400
that's it - the vice weights 26lbs , has 4 inch jaws and opens to about 4 1/2 inches. In the 1935 Record catalogue it is slightly more expensive than the bog standard cast iron 4'' no 3 mechanics vice (29/- vs 25/-) but cheaper than the equivalent swivel base model, the 3S, which cost 33s )
It is pitched as an inexpensive vice for the amateur mechanic or the woodworker who has an occasional need to do a bit of metalwork (where the fact it can be popped into a dog hole on your bench and removed after use is an advantage) and, if the Record marketing maestros are to be believed, was a popular choice in factories and mechanic's workshops up and down the country.
Mine was £62 delivered and, cosmetics aside, is in perfect working order. Pretty good value since it should easily be good for another 80 years at least.
That pic of valve polishing is one of those "how not to" lessons.
Rotating it in the hole would score it like crazy, let alone the fact the face could well be at a different angle to the seat in the head.
You always lap a valve to its seat, or youre just wasting everybodies time. :roll: :roll:
Matter of interest though, how deep are the valve stem holes? They should be several inches, if not all the way through.
There is a "time - line" for these vices, when I got mine, I looked into them.
Early ones have a threaded hole on the right hand side of the moving head to take a the square headed bolt that clamps in the front pipe grip.
Mid ones, this hole is missing, and possibly the pipe grip is not supplied.
Late ones, had different wording cast on both sides.
Last ones, had square ended main screw, and a hex head bolt held the anvil in place.
I don't know the dates of any of the changes.
Record catalogue No14 (1935) Lists the 74 at 29/6 each nett. £1.9.6 (£1.47 in new money.) and lists a pipe grip as an available spare.
Catalogue E.2 (October 1970) lists the 74, with 3 coach screws for base plate fixing. No mention of pipe gripping!
In June 1970 the price is now 180/- or £9 (in new money).
The cylinder head holder is always missing, I've yet to even see one!
These are climbing in value, last year (2017) £30 would buy a usable example, now £60-70+
Just be certain that all the main parts are present, wing nut, washer, serrated base(which has 3 holes to fix to bench. This is the most often part missing, and cannot be got new.) The hard jaws might still be available, if they were common to any other Record vice.
All in a very useful bit of kit, has some good ideas, slightly off-set jaws, allowing things to be gripped passed the main screw, proper small anvil. Then a bad idea, all the crud can fall directly onto the main screw.
All in all I'm keeping mine, too useful.
Bod
Thanks Bod,
that is good info. The earliest one I could find says 'patent pending' on it, so presumably July 1928 and May 1929 (the dates when the patent was applied for and when it was granted), and you are quite right it has got a set screw to hold the front pipe grip which I hadn't noticed before.
9daklQUAKRd28j5deA-xRsjupSlUsQVm0_Ls1vtWxQVTmajxIqBaWaK4YBU=w2400
Ps sunnybob the cylinder head holes are about 2'' deep (almost go through to the other side)
edit - sorry that was the wrong pic above, the earlier one does not appear to have a set screw - most odd...
LUk58NOr1SapBZHV1VvhMotKcBKSXgJPgzqf9ygfG4hmYqyx1QT5yyCJ0U8=w2400
the triangular base was missing from this one and, as you say , they often seem to go missing. not sure why...
here are some pics of the other variants mentioned by Bod. The castings of the two oldest models - shown above - say 'patents pending' (July 1928 and May 1929) and 'patents 310723/28' (1929 - 49?). The use of a set screw to retain the pipe holder seems to have been a short lived experiment in the 30s or 40s.
At some point after the patent expired the casting was changed to say simply 'made in england', and the patent number is also removed from the base.
PnItq7PG-iKyIlkNHk5BMzTcW8uf4MQjZf71IwxHI8TAvzP7HMsngfChrnQ=w2400
Ti5ki2lQi8M_CzcSsiQOhUvNbeEnDXqPFQNZDIdk_2bWsjM499fgHqnb8Y8=w2400
like Bod, I can't see any way to date the other revisions but I think these are in chronological order:
the 'auto vice' branding was removed, as were the two holes that helped hapless mechanics polish their engine valves incorrectly:
HWuNYUVMQvjhG9acxYRFHMoQuWe2UrIoOjciFqARH3hvYkfsL-SzHcaP9so=w2400
in exchanged for the much missed valve cleaning holes Record supplied a more substantial anvil and a hexagonal headed set screw to hold it in place
zDFJ4C_JGiscBpqZzEuqbxJ3y1QOWQIOdKXObARgh1_63i_8PTov5XbFFr0=w2400
and in what appears to be the final version, a square boss is used for the screw. This parallels changes introduced in other parts of the Record vice range introduced in 1963, although the pictures of the Imp and 74 in the 63 catalogue still show a round boss so perhaps this change lagged behind a bit for the auto vices.
The other change made for the 74 and the Imp was the use of a much finer thread on the screw. I'm not sure if this is an improvement or not?
ZnxjpuIAKe-tONcacOHTThg3lNRSjaZz9gl87tezM6l-NxLrYicHgU5o0O8=w2400
PS the above pic shows a (home made?) pipe holder.
owners of these vices who have lost the removable pipe holder attachment (which is to say, all of em!) can breath a sigh of relief since an enterprising ebayer has started making replacements:
ebay
once I cleaned the debris from the slot in the body of the vice it was a perfect fit. Ingeniously a magnet is included that helps locate it in the slot and also means you can attach it to the vice when not in use, thus never losing it again. Happy pipe holding everyone!
5r1vd1LoooApuIXzrCNmcq4ecrXPul7SKkIQ_i8CFCtCNbOcKALgR5GwGvo=w2400
GjaM1QxQXiHGSXHy45J3luh5EWeiAWlu07dqKZZ2LZGnrsAdP8HADZGslsM=w2400
ryZO1ZDJmzRQ8JECjlT9Hit8tGKFRzXbrAkgxuOfiAhmj7XRw6GVA0wpjLk=w2400
