L Class ≤ 1.0% Dusts with maximum allowable concentrations (MAC) > 1 mg/m³
M Class < 0.1% Dusts with maximum allowable concentrations (MAC) ≥ 0.1 mg/m³
H Class < 0.005% Dusts with maximum allowable concentrations (MAC) < 0.1 mg/m³
Well you brought up the class system:
L Class extractors are regarded as ‘entry-level’ with M Class being the next step up. You can broadly separate them in terms of application, as follows:
L Class - for soft woods and solid surface material such as Corian.
M Class - for hard woods, board materials, concrete and brick dust.
In reality, you will find that most professional L and M Class dust extractors will have similar suction rates and filtration levels. This means the applications they can be used for are fundamentally the same. The difference will come down to features on the machine. A true M Class dust extractor will have an audible alarm to advise you when the suction rate has dropped, for example a blocked hose or full dust bag. You will generally find that when working on site, the health and safety manager will insist on using M Class dust extraction. M Class is also the minimal legal requirement, set by the HSE, so these factors alone may dictate whether you step up from L Class to M Class, when making your next purchase.
The next step up from M Class is H Class. H Class dust extractors include all the features you find with M Class units, but also offer greater suction and filtration figures, even down to the way the bag is removed from the machine to avoid particles going back into the air. H Class vacuum extractors would generally be specified if you are working in environments with highly carcinogenic dusts such as lead, carbon, tar, nickel, cobalt, copper and cadmium along with other really nasty stuff you really don’t want to be breathing in!
H Class - highly carcinogenic dusts, asbestos, formaldehyde, mould, germs and bacteria.
Now we’ve ascertained that the use of dust extraction is essential and we also know which class of extractor best suits our needs… the next question is “what other features are available and which extractor do I go for?”
Most professional and industrial dust extractors have power take-off which allows you to plug your power tool directly into the vacuum extractor, making the unit automatically turn-on when the power tool is started. This removes the need to turn-on the two items separately. There is also a delayed shut-off; when the power tool is stopped the extractor continues to run for around five seconds longer to clear both the tool and hose of any remaining particles.
But none on this has any bearing on the difference between a HVLP and a LVHP extractor, if you are sanding materials then you need a vacuum cleaner type unit, with filter bags etc, if you predominately use planing machines and the like then you need a HVLP extractor the type of filtration to either is down to what you want to achieve on air purity, you could do nothing and use an efficient air entry mask, not advisable, your clothes would be covered and you will transfer everything on your clothes with you into whatever environment you go to next.
To get back to your problem, most of the members on here have compromised their extraction systems due to various restraints put upon themselves by the amount of workshop space they have (budget should not be a factor) the LVHP vacuum cleaner type of extractor is good for dust, the higher the pressure the better, each motor is rated at Watts, but this is only half the story, the amount of stages a vacuum unit has makes it more efficient, twin motors, twin stages, a single stage unit will struggle to achieve over 150m3/hr, double the stages and you will effectively double the extract power, these units will not move large off cuts of material effectively for that you need a HVLP chip extractor, even the smallest of these will give 500m3/hr extraction at half the cost of a vacuum cleaner, but still struggle with a large volume of chips, for this type of extract it is better to overwhelm the required amount of extract power, I would advise at the very least 1500m3/hr.
Mike
Sorry guys I think I have turned into ETV.
