Artist brush holder...Prove the concept
manxnorton
29 Jun 2016
Newcastle
Hi all,
Staying on a 'Artist theme', my sister just showed me a picture from the net.
Got me thinking.. :?:
I only had soft wood to play with.
Proving the concept is my favourite saying just now lol.
So here goes, (worts and all lol (hammer) )
I knew the grain would be a problem :twisted:
Trying 12mm dowel.
I could sanded and sand it till the cows come home...but maybe with the right wood proven it could work.
Sorry about the rubbish brushes lol.
Thanks for viewing, comments welcome.
Bri
09/11/18
Hi all,
been messing with a more brush holder.
this one has 22mm holes.
Only prob the 12mm dowel bit is too big to fit onto the pillar drill press :cry:
So any angle difference was made with ME and the battery drill... :wink:
crooked like my back #-o
Thank you for viewing.
Bri
They look ok mate. Dont be so hard on yourself!
Are you clamping the two flat sections and drilling them together? That will definitely help. If you have a combination square or even better a couple of engineers squares (for ease) you can put one on either axis, front and side of your drill bit. Will help you keep your drill bit at 90 degrees. If not a couple of bits of offcut will do. Use the shop cut surfaces: ie the side and bottom of a 2x4 etc. Not a self cut end.
If you're drilling near an edge or corner like here even drawing the line down the edge of the piece can help.
No expert by any means just trying to help.
I think you're going great guns Bri. =D>
Look forward to your posts.
Chris
(edit... was looking on the phone yesterday and didn't realise the holes for the posts were only partially drilled on one (the wonkier one?) so maybe that's it.
Spent three hours yesterday trying to deal with compound errors myself. :evil:
You are not alone fella. )
Chris
Great Chris,
I ordered small 12mm wood drill bits for the pillar drill.
Should get me near perfect holes :lol:
I'm enjoying myself no end.
Ordering a jointer/planer in the mo...….held on for so long!
research etc, theres a time to find out if its worth it lol.
Bri
Morning all,
Well eventually got a trim router after ordering a 110v one :oops: :oops:
Teach me to do online shopping and not scrutinise.
Here we go... (hammer)
test piece.
needs sanding, I had to lower the bit.
Test piece Roman Ogee...ok..but ill stick with round over bit for now.
Our lass reckons if I router the whole house shes going to leave me...…. :wink: :wink: :wink:
Best not...shes better cook as I am #-o
TBH was a bit scared of the thing lol.
The leads get in the way :cry:
P.P.E. done...off to play.
Bri
They look really useful, nice job. On the mouldings, I always find them easier on a table.
Thank you m8.
a router table and bandsaw in the new year me thinks :wink:
Bri
Bm101":2tnztzkr said:
Good to see you back on here Bri. Missed you.
Chris
Thanks Chis,
Aye the Xmas period and then the winter has mashed me in :cry:
But...………...like I always do bounce back! :lol:
I put a few projects on YouTube, nowt exiting as im not a guru as you know with tech stuff.
I'm putting plans projects in a mo.
Thanks again, hope you and yours are ok?
Bri
