Four stainless hex-headed are on their way by first-class air mail. HTH
Ray.
Ray.
Chems said:Why not just use the Quick release screws that the triton has on it. I replaced mine with a set of M6 bolts that were slightly shorter to alow it to tighten. Then I just countersunk them into my base plate:
Apologies for reviving an old post but I'm trying to get going on a router table quickly and cheaply.
If I understand correctly you used the two holes for the extended baseplate to screw 2 M6 bolts into to mount into your table?
How did that work out for you? Was it stable and secure? First timer so a bit nervous. Also I just bought some M6 but they don't thread into the hole which seems larger on my MOF 001, maybe it's different to the TRA001?
Cheers in advance
Hi Ray,Argee":de3k4dxl said:Still here, just not so often!
