It all seems a bit much really as the most of the dust is actually taken away using the normal extractor, thou i guess if you have time on your hands then this is fine ...
Take a look at PWM's range of dust extractors I have no connection to them - I signed up to their newsletter when I bought a dust shroud for an angle grinder.Peter Sefton":20jsfl3z said:If anybody has any suggestions for a better small extractor that is not too tall max 900mm please say so.
Cheers Peter
HiPeter Sefton":1ajncne9 said:Hi a couple of photos of my modifications, I should say I never had an issue with dust from the Bandsaw when it was connected to an old NU tool extractor that you may see in the background. Only when I had too move machines around to fit in the new Felder A741 Surface planer. I then put the Numatic on the Bandsaw and it’s just not really man enough.
I need to use a low level (short) extractor as it’s a bit in the middle of the machine shop and too involved to be piped up to a bigger system.
The new 100mm extraction outlet is off a felder Bandsaw and is fine but I have made a plywood slope inside the bandsaw body to assist the extractor. The Numatic just passes the LEV test but only just so if anybody has any suggestions for a better small extractor that is not too tall max 900mm please say so.
Cheers Peter
Have you seen this solution?E-wan":1himkzan said:Should I be concerned about any impact of structural integrity on the bandsaw frame from removing this small piece of metal?
