Help, properties of a curve/circle
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Is there a way of finding out the radius or any other properties of a circle with only the following information:
(very technical drawing of flexible rod pulled into a curve with string)
Do you know the height of the segment?
If you do there is a formula.
Pythagoras's Theorem, sines and cosines will get you there.
The black line is your string. The red line you haven't told us yet, but you need to measure it.
Crucially, the shape of the triangles A and B is the same, but the sizes are different. This is because wherever a triangle from the diameter of a circle touches its edge, the angle is always 90 deg. (the triangle made by the green and blue lines). The big triangle is also the same shape, as it shares the same angles with the other two.
So work out the missing distance in triangle A (the green line of it). That can be dropped into the big triangle, allowing you to work out both the other green line and eventually getting you to the diameter of the circle (blue).
Note that this is an approximation, because the "bowstring" method actually makes a bit of a parabola or a catenary (a proper engineer will be along in a minute...), NOT an arc of a circle. But it's probably close enough for your needs.
You need a calculator that can do sines, cosines and arcsines, etc. as you'll be swapping between angles and distances. It also probably needs to do degrees (at least I find them easier than radians!).
HTH, E.
If you know A above, then it's a simple formula with no sins, cosines etc.
Thanks Bob, Novo and Eric, knew I was missing something.
This is a difficult problem to solve with the info given, but not impossible if you have the relevant mathematical software available. Fortunately it is available at https://planetcalc.com/1421/
This screenshot gives the answers with your data fed in:-
Brian
No it will be a parabola which doesn't have a radius. It wont be too far away from an arc if it is 'shallow' though so the formulae above will be a reasonable approximation
cheers mark
If you've got the rise of the curve -
7816mm diameter
As an aside, the distance "A" from ErictheViking's diagram is approx 120mm.
Sheffield Tony":17ds50pm said:
I'm fairly sure a rod tensioned by a string will not be a circular arc.
No, it won't.
More importantly, people have been hand-making bloody good and accurately sized Longbows for centuries, without having a clue who Pythagoras even was... So there must be some even simpler tricks!! :D
Thanks again to everybody who has posted, all have been useful and educational.
Ta.
