woodbloke66
One of the big problems I face when making a drawer bottom is gluing up narrow bits of Cedar of Lebanon and 'attempting' to keep them flat and level. I've had real problems with this in the past, so I developed this method of gluing up sections for a drawer bottom. The current job in the 'shop is a large unit with eight small drawers and four big ones. This is the smallest of the;
...large drawers with a metre rule alongside for a size comparison.
To make the jig, I start off with piece of flat 18mm ply which is bigger all round than the drawer bottom needed. Onto the top surface goes some parcel tape (to stop glue sticking) and on;
...the underside I screw a large chunk of stuff to iron out any slight bow in the ply.
At each end I then screw on a pair of battens, ensuring that the gap between them is equal. Next comes a pair of sliding wedges which need to be made fairly accurately and also another three battens;
...with parcel tape on the underside.
Ideally, the CoL needs to be quarter sawn and without knots or blemishes;
The material can then be cut about a mm over thickness, with one planed face against the bandsaw fence;
...so that now it's possible to see the defects;
These can then be removed and the sections planed a fraction over thickness, after which each edge can be shot in on the shooting board;
I check to see the whole stack butts together well under moderate pressure from the wedge (using light taps from a pair of hammers). The sections are then glued;
...and cramped dead flat against the plywood board;
After a couple of hours, it's safe to take it out the jig and provided the Gods have been smiling, I end up with a flat, quarter sawn drawer bottom;
...which only needs the barest minimum of scraping/sanding to bring it to a finished thickness. The method is a bit convoluted but provided the sequence is adhered to, the results are usually pretty good - Rob
