Racers
- Joined
- 22 Apr 2005
- Messages
- 9,172
- Reaction score
- 132
Another box with a peel lid, Lacewood top, pallet wood sides, cherry bottom and rosewood hinges.
I planes up the sides to 15mm mitred them on the shooting board cut the rebates for the hinges and glued them together, then sawed and plained angles.
I glued two pieces of rosewood for the hinges at 90deg to avoid having short grain across the pins, cut out the hinges and glued them in.
The top was cut from a thicker piece of Lacewood and the corner shaped with rasps, sandpaper on a dowel etc.
Slots where cut for the hinges after drilling the pivot holes, the top was clamped to the box and the hinges where drilled, a bit if adjusting was done to get the lid to go just over 90deg.
The box was finished with Danish oil and wax.
A quick shot with a Lensbaby composer pro and sweet 50 optic.
Lacewood box by Racers, on Flickr
Its 68mm square.
Its 68mm square.
