Skill building projects (scarf joint and a plane)
B3nder
26 Nov 2016
West Kent
I've been working on my hand tool skills. (After restoring lots of tools).
After about a year of mucking around and lots of trial and error it seems like I am finally turning the corner.
So I thought I would post a couple of projects.
I am working towards making a guitar neck so thought I would try and get the scarf neck joimt sorted.
There seem to be lots of tutorials usong power tools, not many using hand tools.
So cutting a 13 degree (ish) angle to create an invisible joint was trickier than I thought.
This was my 3rd attempt:
And the other side:
I am pretty pleased the only issue being camping which meant the first picture shows glue where I should have clamped on that side as well!
The plane build came around as I have lots of scruffy wood.
So started to plane it square then diacovered th EnglishWooWorker plane build and an old blade and chip breaker.
So I started with something like this:
Which turned into this:
The blank I started with only yielded one side piece. As a result of doing this all on a whim.
Next step was cutting the angles and glue it all together hence:
Once the glue had dried I realised that the top face wasn't flat so I decided to plane it flat. Which started well until a couple of pieces aroundth screw relief broke off :evil:
I'll sort a picture of the break out.
Lesson learnt though, I should have made sure it wad flat befoe I glued it up and chiseled out the screw relief.
Anyway I then checked to see if the blade would sit flat and there as a little wiggle room, resulting in this:
Good fit, flat and room to tweak.
The onto the wedge which is done just need some pics, which I will upload a little while later.
Wedge made, I just need to trim it to size:
So I thought I should test it to see how it turned out:
Which I am rather pleased with. Not sure about putting a handle on or not. As I have other things to sort out I suspect it will be a while until I sort out a handle.
