Jubilee clip alternatives?
MikeG.":26yudd0k said:
Zip ties.
Pull a large-section zip tie tight with a pair of pliers and snip off the excess. This will hold really high pressures, and many a Landrover has crossed Africa with zip ties holding its radiator hoses in place. Quick, cheap, and easy.....and works every bit as well as any of the proprietry solutions you've been offered.
Fully agree - cable ties are the way to go - just make sure it is lined up with the trough part, and not the peak part of the barb.
clanger":ltbx4zie said:
MikeG.":ltbx4zie said:
Zip ties.
two with the locking bits at 180 degrees is better or three or four............ as they are dirt cheeeep
