Dalboy
Small hollow form 3" X 4 3/4" with an 1/2" hole sanded inside and out to 400grit then textured on the outside finished with ebonising spray and dry brushed with pink iridescent paint Ok I know it does not look pink
CHJ":92chswyl said:Neatly done, looks like I could learn a few wrinkles from you on the texturing front, not to mention the patience to spend the time achieving it.
Guess I'm just going to have to learn how to use these with a bit more enthusiasm.Dalboy":2p6pwn7k said:The texturing took about an hour ........
Just a cheapish Dremel look-alike with a flex drive attachment Derek, got it initially to help blend in 'natural defects' to look a little less obvious, time will tell if I have enough patience to match your efforts and warrant more robust kit.Dalboy":1j8rehuy said:Take frequent stops to rest your hands depending on the machine you have.
Dalboy":30gorqh4 said:Take frequent stops to rest your hands depending on the machine you have.
