Myford Lathe Advice
gregmcateer
16 Jun 2011
Stourbridge, W Midlands
Evening Folks,
A friend who's Dad has passed away and would like to move his old lathe has asked me to see if any of you good people know;
The model of this lathe
The dismantling and transportability - i.e. Is it relatively straightforward or specialist?
Many thanks in advance,
Greg
It's an ML7 but a high end version with gearbox and clutch.
You will need 2 stout men to move it, but otherwise it's not too bad. They are very badly balanced towards the headstock end so take care there. I recommend removing the tailstock, chuck, cross slide and motor as a minimum.
Nice looking lathe though and extra desirable with the gearbox on it.
Blockplane":1vmznnoe said:
Myford 7 series, looks to be a Super 7. Fairly straightforward to move, given sufficient manpower .
Certainly not a Super 7. It's an ML7 (I have both) with Gear-box.
Taken off the stand it can easily be moved by two men in reasonable health. I'm 76, 10st 3 and two days ago I moved my Super 7 from one side of my workshop to the other (about 2½ metres) on my own. ---- No I didn't 'pick it up' -- I 'walked' it :D
I had to carry my 7 in to the garage on my own as my lads were away at work :cry:
It was the same when I traded a woodlathe for this Granville Snior, Removed bits but still almost broke me back!!
And again when I 'won' this Startrite bandsaw off the bay, Two big lads put it in to my car but I was on me todd again so I got a spanner and stripped the saw from the stand, Almost all the weight is in the saw though!
John :p
