White Bird, John Berger
Chris152
26 Apr 2017
Cardiff
Having a little break from making and yesterday I read an essay by John Berger called The White Bird. I like the essay and got to wondering if any of you had actually made one. Here's one that I think is what he's describing:
and here's how he describes making one, in case you want to have a go:
The principle of the construction of these birds is simple enough, although to make a fine bird demands considerable skill. You take two bars of pine wood, about six inches in length, a little less than one inch in height and the same in width. You soak them in water so that the wood has the maximum pliability, then you carve them. One piece will be the head and body with a fan tail, the second piece will represent the wings. The art principally concerns the making of the wing and tail feathers. The whole block of each wing is carved according to the silhouette of a single feather. Then the block is sliced into thirteen thin layers and these are gently opened out, one by one, to make a fan shape. Likewise for the second wing and for the tail feathers. The two pieces of wood are joined together to form a cross and the bird is complete. No glue is used and there is only one nail where the two pieces of wood cross. Very light, weighing only two or three ounces, the birds are usually hung on a thread from an overhanging mantelpiece or beam so that they move with the air currents.
