Doug B
Shy Tot
Don’t know if this is of any interest but a while ago I made myself a MFT for using on site with my track saw.
I started by making a template on a friends miller
Setting the 30mm holes at 96mm centres
After which he turned me up some aluminium dogs starting with the long ones
Cutting them down on the bandsaw
The finished 19mm x 30mm dogs
I clamped the template on an offcut of MDF, using a 19mm cutter & 30mm guide Bush I cut holes in to the MDF with my router, I then moved the template along using the dogs to reference the template & continued cutting holes
On site the top is simply mounted on a couple of trestles though I fixed a couple of bearers to the underside for rigidity
For 90 & 45 degree cuts I find the top extremely accurate as well as being a very convenient work surface.
