custard
Mitred dovetails got mentioned in a recent thread, they're a useful joint for certain applications so I thought I'd do a short WIP in case anyone's inspired to have a go. They aren't difficult, but it's best to follow a proven process pretty closely.
Step one is to get out some stock and mark it up.
Whenever I'm dovetailing, even on a test piece, I like to use the standard markings used all across the English speaking world for drawer components. The tail boards (drawer sides) each have a quadrant in the lower front corner on the outside, the pin board (drawer front) has a semi-circle on the bottom edge on the outside. If you were making drawer and had a back as well then that would also have a semi circle on the outside lower edge, but this time with a vertical line through it. The advantage of these markings is that you'll never get confused regarding the orientation of dovetailed components. If you're making a piece with multiple drawers then it's common to add a number to each of the symbols.
Even for a quick test piece like this you must have straight, flat, and true components,
Unless your boards are completely true you'll get into a right mess with mitred dovetails. Unfortunately many hobbyists embark on projects with boards that look more like this, and to be clear, these simply aren't true enough,
This doesn't get spoken about as much as it deserves. Accurately and efficiently truing stock with hand tools requires quite a lot of effort and practise; but unless you have access to good quality machinery there's just no alternative to acquiring those skills if you want to make clean, professional looking furniture with gap free joinery.
I guess anyone making mitred dovetails will have already cracked basic dovetailing, so I'll skip through some of the basic stuff. I normally work tails first for dovetails, but for some reason I prefer to work pins first on thicker stock or with mitred dovetails. These boards are 30mm thick so I'll work pins first. Mark up the pin board using your normal preferred method, mark the waste, and then do all the vertical cuts exactly the same as for a normal through dovetail. I saw straight to the line, I don't want to faff around with paring if it's not necessary and personally I think paring on through dovetails is simply less accurate than aiming to do the job straight from the saw. I appreciate that paring the pin board on lapped or half-blind dovetails is appropriate, just not on through dovetails.
Incidentally, I'm using a 1:7 slope, but you can obviously use whatever you want. So you should now have something like this,
So the next stage is to hog out the majority of the waste down to about 1 or 2mm away from the scribe line. I use a fret saw but again, use whatever method you're most comfortable with,
I think I've reached the limit for number of photos in a single post so I'll pause here and pick up the story in the next post.
