Felder Table Saw - Replace that Plastic Guide!
RodTungsten
New member
4 May 2017
Pewsey
A local cabinetmaker had frequent issues with his Felder table saw when cutting small mitres and other jobs on the saw - problem was caused a plastic guide by the side of the saw blade which flexed and usually cracked when offcuts jammed between it and the blade.
We provided a solution - an aluminium guide which completely replaces the 'consumable' plastic guide and gives a level and stable surface to cut with.
The picture shows the new guide fitted to the Felder Saw.
Contact me if you want one of these.
