Where can I find this type of reducer?
13 Jul 2015
Wales
This isn't for dust extraction, it's actually for something completly non wood working related, but I am trying to source something like this
It doesn't have to be those exact measurements (90x34), around ~100mm by ~35mm, but it does need to match the shape. Any ideas? I know that record do something similar, but it's not the same shape.
I thought I'd find this kind of thing in Wickes/B&Q etc in the guttering section. But no :(
Any of these any good?
They're spares from the Dust Extraction box of bits, you're welcome to them.
Thanks Custard! .. but I'm really looking for that specific shape above (~100mm to ~35mm) ... for ...aesthestic reasons :p
tell us why you need it and we might come up with better solutions for you.
in the meantime i suggest you try places like pond plumbing suppliers - they stock lots of unusual pipe fittings you dont get in domestic plumbing suppliers, and they are usually available in waste pipe and pressure PVC pipe specifications
you'd be looking for a 4" to 1 1/4" reducer (most sizes are imperial in the pond world)
http://www.discountleisureproducts.co.u ... ttings-c20
https://www.cdaquatics.co.uk/pipes-fittings-and-valves
https://www.allpondsolutions.co.uk/pond ... -fittings/
hope they help.
It looks exactly the same as a rubber boot protector found on large trucks and industrial vehicles, they are fitted on brand new track rods and drag links so the rubber isn't damaged in transport before they are fitted onto the vehicle.
soil pipe is 110mm waste is typically 38mm. not very often that the two meet, even less often they meet in this way. makes for a rare fitting in this country. in the states it would be 4-2" and is much more common.
Proper pipe, not metric drainage pipe, is designated by its nominal bore. 4" pipe has an outside diameter of 4 1/2" or 116mm. 2" pipe is 2 3/8" or 60mm. So it is not even close to 4" x 2".
