Bernzomatic Braizing torch
In the uk, 0-4% of finding one. You might get old stock somewhere.
Think they've been banned. To many bangs from people doing stupid things.
Ok thanks. That is probably why it was so cheap!
I will likely go for a complete kit like this one
OXYTURBO TURBO SET 110 - PORTABLE WELDING KIT at least I will have no trouble getting the consumables.
The screw thread and valve on the cylinders for these are the same fitting as used on the heavy, higher capacity but disposable Coleman cylinders. Berneze do (did ?) plumbers torches for soldering and brazing that fit direct to one cylinder only using this fitting.
I haven't looked for many years but I remember that oxygen was horribly expensive in these small bottles.
The Mapp gas is easy to get hold of, screwfix, bit i think you would need a turbo torch that screws directly on the can. It will braze smallish things.
The Oxy bottle i wouldn't touch with a barge pole, not in a tin can anyway.
They are about 18g i think, the weight comes from the gas (liquid).
I was used to working with steel up to and above 2in thick, anything below a 1/4 in is tin for me lol
