• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
Makita 2704 Table Saw with Stand, 230V
Togalosh
22 Sep 2011
Enclave Des Papes, France
Hello Gents,
Due to a recent upgrade I now have this table saw for sale. It has stood me in good stead for years of relatively easy, part time use & has been well looked after in a cosy workshop. It has never needed repairing & as far as I know it is in full working order. It has a general use blade fitted & there may well be a spare blade too. There are some scratches to the top from fair usage & I have marked my initials & postcode in the plastic body which I will try to cover up, otherwise there is no damage. No parts are missing.
The Trolley /Stand, which has had even less use than the saw, is also in full working order & is FOC with the saw.
I am asking £350 - collection from south Birmingham preferred.
Putting it on a pallet would not be at all easy or convenient but not impossible. You would have to organise the courier collection.
Technical specifications from Makita website:
Depth of Cut @ 90°: 93 mm
Blade Diameter: 260 mm
Depth of Cut @ 45º: 64 mm
Hole Diameter: 30 mm
Bevel Angle Settings: -0.5 - 45.5 º
Rip capacity with sub-table: 8 x 4 ft sheet
Table length (with sub-tables - included): 665 to 1045 mm
Input wattage; 650 w
No Load Speed: 4600 rpm
Net weight: 30.0 kg
Togs
Hi, I'm interested in buying your saw. I may be able to drive up to you one evening next week. Is that any good for you? Thanks.
Hi,
I do not work set hours & often work late (tonight I got home after 9) so it my be difficult to do at short notice. I am planning on being home at a reasonable time on Friday. It depends how far away you are I guess.
