Cast iron boat shaped plane
Bedrock
12 Feb 2014
Hampshire
These are the photos of the cast iron plane I referred to in another post.
It is 8" long,2 3/4" wide, with a 2 1/4" blade. Weight is a hefty 3lbs. 13oz.
There is no makers mark, but the cap iron is from Matheison, and the blade a very worn Thos. Turner.
The lever cap is a neat brass casting, and apart from the severe abuse, it looks professionally made.
The front infill is damaged beyond repair, but as far as I can judge, under the grime, the infills are rosewood, held in place by woodscrews in the sides and rear. There is a small chip around the rear fixing screw where it has been hit, and the wooden wedge is beyond hope.
Hopefully, someone will have some idea of it's origins.
Mike
