Log cabin Leaking through corners
snappyfish
New member
23 Oct 2017
Dorset
Hi,
I have a 44m Log cabin with interlocking asymmetric sections at corners. It's a long story but the outside corner sections have gaps off maybe 1mm - 2mm.
Rain is hitting corners running down and through these gaps.
I wondered if anyone has a good solution of how to seal these gaps up? and keep it looking neat and tidy.
A couple tubes of silicone should sort you out.
MikeG.":1olfzxk6 said:
Apart from taking it all to pieces and caulking it as you go, you mean? ;)
Wass fitted in July, Took it down in end of September. Rebuilt it higher off concrete to allow airflow.
Corners where never great even when it was built the first time.
Thanks, you recommend anything that's good for this type of thing. Also worried water my get behind sealant and not drying out?
