New toy
TFrench
6 Jul 2015
Leics
I know you guys will appreciate this. We have an old fobco star at work that is just about ok, but struggles for capacity. I've been looking for something bigger for ages, then spotted this listed on eBay as "radial drill" with very little other info. Did some research, found that it is a oerlikon ub2 and gets a very good write up online. Did the deal, after much faffing around we picked it up today (friendly farmer with telehandler) and got it sited in our unit. Came with a massive amount of Morse taper drill bits, chucks and reamers, and in another box was a load of clamping gear, including a load of lenzkes bits and bobs. Very happy with the result! Will get it powered up next week hopefully when the plug for the bus bar turns up. Can't wait!
Probably still got another life left in it, if not more. Old tool are only old in numbers of years that does not mean they are junk because they are definitely not.
Its nearly there now. Got the power down to the wall box and all connected up. However I appear to have cocked something up as its still not working... sparky coming to look shortly.
I have found this:
Given the construction of the drilling-head and cylinder, it is somewhat surprising that Oerlikon did not opt to design-in an oil bath for the gearboxes. Instead, all lubrication is taken care of by an oil mist gun applied to numerous holes in the casing and coating all the internal components with a smoke-like dusting of oil.
On this website http://anglo-swiss-tools.co.uk/oerlikon-ub2-drilling-machine/
(worth a look if only for the action shot of it drilling a base on a properly giant radial arm drill in the Oerlikon factory)
Any ideas on where I can get such an oil mist gun? Or are we thinking a modern aerosol can oil is going to be as good?
just spotted this
I thought my recent purchase of an arboga was "different"
this is serious toy to say the least
Steve
I have found this:
Complete noob so I can't help much but I'm on a tea break from working on my (what now looks like a childs toy :shock: ) Meddings, so what better thing to do than read about your monster. Googled 'oil mist gun' 'cos ya never know....
http://www.machinerylubrication.com/Rea ... ubrication
This looks informative on the whole shebang including oil types etc, at least to my uninformed eye.
Hope it helps. Good luck with the beast.
Chris
Cheers Chris. It's more the way to apply the mist that's the problem - I imagine the original thing was a grease gun style thing that gave a burst action when you pushed it onto the port - almost like a diesel injector. I've emailed the guy who runs the anglo-swiss website and he said the original lubricator is long out of production. Most of the modern ones seem to have a dedicated high pressure air feed and an oil reservoir and are permanently plumbed in. Think I'm going to try something like this:
https://www.cromwell.co.uk/shop/lub...precision-lubricant-spray-400ml/p/ROC7716551D
