Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,599
- Reaction score
- 74
The roll pin has made the holes off-round, which is part of the problem.
There is a plan:
Attempt #1: will try to get the hole(s) to be a snug fit for the 6mm pin I've got as a spare part.
If that doesn't work,
Attempt #2 I've had the kind offer of loan of a 6.35mm reamer. I have some 6.35mm silver steel bar (on the desk as I type, as it happens). so will ream out to 6.35mm (I think I've got a 6.1 or 6.2 good quality jobber drill somewhere). The only issue with that is cutting the bar to length and drilling it for split pins (and washers, but if I can achieve that it's probably the best solution.
I daren't go bigger because of the location of the holes, but that should work. I need a good day to do it too, and life is busy presently, so may be a week or two.
Appreciate all the ideas - wouldn't have thought of opening it out to 6.3mm on my own (brain fugs too easily!).
There is a plan:
